Engine Idle Speed set up
From Sri Lanka
Hi Guys
I am not aware about how to setup my engine idle speed myself, likes to try it a bit so any time on my own,
has any one got how is it done ? i was looking at my mechanicwhile he is doing it,Carb has 2 adjustments one is Accelerator padel turning it clock wise increase engine rpm, other one is i think fuel air mixture screw turning it clockwise reduce engine rpm and become it smooth and wise versa, correct me if i am wrong guys
i know this is all with expierience but would like to know basic adjustment
thanks
Regards
sumith
Posted on: 2010/7/30 4:54
Re: Engine Idle Speed set up
Yes, that is correct.
It is part of the Tune-up. Here are the basic settings:
Adjust carburetor at full operating temperature. Verify choke is fully open before adjusting
1971-1972 manual . : 750 best idle, then lean to 700 rpm
1971-1972 automatic: 780 best idle, then lean to 750 rpm
(check for 600 rpm in drive after adjustment)
1973 (all models). : 800 rpm leanest smooth idle
automatic. . . . . (check for 650 rpm in drive after adjustment)
Posted on: 2010/7/30 4:56
From Sri Lanka
Hi DD
My Car tend to die on Load (when i put it to the gear or when i put head lights on)not all the time but sometime
you can keep it start for any time but when you engage gear or put head light sometimes it will die
do you think that is with idle setup ?
thanks
Regards
sumith
Posted on: 2010/7/30 5:09
Possibly, yes. It needs to be reset once a year.
Posted on: 2010/7/30 5:32
