flared/pumped guards for wide rims
From campbelltown (sydney) australia
hey guys its now christmas day by 35 minutes, just wanting to know when u get ur guards done so u can fit wider wheels whether it changes the look of the guards much? and also is it better/easier to get leafs reset or make up proper lowering blocks for the back?
Posted on: 2003/12/24 14:27
Re: flared/pumped guards for wide rims
From Sydney, Australia
You understand how that springs are set so that they are soft for the first part of their travel, and get progressively tougher the more they are compressed? This is to improve ride comfort. Now, if you put lowering blocks on, then you don't get tough spring resistance until you've already hit the bump stops, so it makes the car look good and handle not much better, trust me when I say, if you go hard around a corner, hit a pothole, and the suspension hits the bumpstops, the car will exit stage left into an oncoming telegraph pole...
This is not from personal experience, but I know of others who've shared this fate.
The idea is to lower the centre of gravity, without stuffing up the roll centre. This is a complex topic. Using reverse eyed, and tougher set of springs, keeps the progressive nature of the springs. But the REAL benefit is only found with good quality shock absorbers. Lowering the car 1-2 inches is fine, and get the best shocks you can get your hands on. Good tires also make a huge difference. On my first Datto, I splashed out on a new set of P600 Pirellis, and the difference was HUGE.
So there you go, this is the end of my Christmas morning spiel.
Merry Christmas to all. And Happy Holidays for people who believe otherwise.
Posted on: 2003/12/24 23:53
although ur info helped in a way u didnt answer my questions!!!! i also wanna add another question, if i end up needing new rear, or redone leafs how much does it cost and where do u get this done?
Posted on: 2003/12/25 13:54
ok..Here I go.
Nobody can answer your questions with any certainty without knowing EXACTLY what front struts/calipers/lower arms/castor rods you are using. Even if they do answer it, the suggestions may still be way off. Most of the racing done in 1200s was done in Sedans or Coupes, so they'd only ever be unreliable approximates, especially with the different weight distribution between the models.
For tyre size, the rear is easy. On a lipped guard you can just squeeze 205/60/14 on the rear in a sedan, I expect 215s will fit a Ute. You'll need custom offset wheels to fit this.
Based on my assumption that this is your only form of transport, and you drive quite a bit. Here's a summary of my advice:
1. Get 185/195 size tyres on a 5.5/6 inch rim in a common size.
2. Lowering your car will make almost no difference to handling (if that's all you do)
3. Getting 16+ inch rims will mean you have to fork out $800 every 2 years for tyres, because of the low profile for 1200. The car will also wander all over the road with wide tyres.
4. To flare the guards properly for > 205 tyres, they'll need painting afterwards, if you have special paint, it'll need a whole body respray to paint match.
5. Call Pedders about your spring/shocks/reverse eye requirements. They should be able to talk sense. Do the suspension as a package, and get someone who is REAL, to guarantee that it'll work.
6. Make sure that you get the best shocks that you can afford.
7. Only get the guards "lipped", to preserve the 1200 lines.
8. Don't use lowering blocks for more than 1 inch difference.
9. Using the same size/offset tyres on the front and rear means you can get out of trouble if you get a flat tyre, it also saves on tyres costs, by allowing you to rotate the tyres at least front to back.
I'll be an old man, and also say this:
Suspension upgrades, in conjunction with putting larger tyres on, is a serious undertaking, and those who aim to satisfy "looks" requirements over function, will be driving a different car in less than 12 months due to back pain from poor ride or accident..
Some may say buy some cheap second hand parts, but buying suspension parts from a wreck is risky, as it was most likely the cause of the other guy's crash
Save up $1000, then talk to Pedders.
Posted on: 2003/12/25 14:44
Not too shy to talk
From Perth, Western Australia
Is that how much it'll cost for the lowering only or is that everything needed?
I'm trying to find out how much to expect for lowering my sedan properly... Your advice is wise...
Posted on: 2003/12/26 3:12
From Melbourne, Australia
reseting springs is around $200 i think
lowering blocks around $50 depends on how they are made ect
good shocks if ya dont have em, $150
urethane/nolethane rubbers $70
for a road car, use lowering blocks and new shocks,
otherwise reset springs, shocks and rubbers would be best
Posted on: 2003/12/26 3:19
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
is it 200 dollars for the rear springs by themself or 200 for both the fronts and rear? what places do this sort of thing? should be able to make my own blocks as my dad can do it all at his work with milling machines and so onjust gotta by the aluminium.
Posted on: 2003/12/26 8:38
200 for the leafs, get king springs or whateva for the front
that price is approximate as ive never had it quoted, hopefully someone whos had it done can say more
for blocks you also need a bolt holding the leafs to the springs (an extended bolt to locate the diff aswell), and longer u-bolts aswell
Posted on: 2003/12/26 11:20
1200 Coupe Rallycar
This is what I'm talking about. These things should be replaced with new parts. Getting them from a wrecked car could mean the risk of the metal being fractured and might break at an inopportune time.
Get a quote for lowering the whole car (as one job) from a reputable suspension place. If you want to work with the drug dealing small shops, do so at your own risk. They will quote less and deliver less.
I'd recommend Tokico Silver or Golds, but they don't import here anymore. So go for some Koni or Bilsteins, but if you have to, using the Pedders branded stuff is ok too. So long as you get a 12 months warranty, and drive it appropriately for the first 12 months. DONT USE Gabriel or Monroe under any circumstances..
Please budget at least $500 with the possibility of it costing up to $1000 for 4 new shocks, reverse eyed rear springs and sports springs for the front and maybe a new front swaybar (Although 120Y one (With mounting brackets, works well). If you save money by doing it yourself, it may never be right.
Cheers,
Chris
Posted on: 2003/12/26 14:26
Dattodude is on the money.
It can be done cheaply, or it can be done right, & doing it right often turns out to be the most cost effective way. Someone once told me "Poor man pays twice"
I learned the truth of that the hard way.
Posted on: 2003/12/26 16:37
Love your Datsun.
Treat it well.
