Drag link question
From Sydney
Hi I want to replace my drag like on my 1200 coupe. According to a seller on eBay selling a drag link, he says that the straight one is no longer available. Is this true? Wiki says the one with bends will fit? Is there any major differences when the straight drag link is replaced with the bent style. I don't want waste money on this if it's not right. Cheers
Posted on: 2011/5/7 15:07
Re: Drag link question
From Brisbane Australia
bent ones are 120Y they fit fine
Posted on: 2011/5/7 22:50
From Sydney
Thanks that's a great help
Posted on: 2011/5/8 1:47
From BlueMountains NSW
if you are still looking ,I got mine from REPCO same price as EBAY when you include freight
and you have someone to come back to if it don't fit. Cheers bazz
Posted on: 2011/5/11 3:22
I DON'T LIVE IN THE PAST....I JUST TAKE DAY TRIPS
From Seattle ,WA.
I dont know if they ship to AU but here's one...
http://www.rockauto.com/catalog/raframecatalog.php
Posted on: 2011/5/11 5:36
Here's a comparison of RHD B110 to RHD B210:
B210 drag link has a kink in it for clearance
* B110: 48560-H1000 ROD ASS'Y-CROSS RHD
* B210: 48560-H5025 ROD ASS'Y cross steering RHD
Here's where it fits:
Posted on: 2011/5/11 7:50
From Nyngan, nsw Australia
ddgonzal witch has used my pic illustrate the differents between the two, i ordered B120 and recived B210 all bolts up the same, witch works just aswell
Posted on: 2011/5/11 10:06
living is good,.....
anyone got a pic of a 120y one installed, looking at upgrading the one on the sedan, not sure if it will cause issues for clearance with the bends.
Posted on: 2011/5/12 11:23
From Sydney
Thanks for all the replys. I got a original style 1200 drag link from Peps. I have noticed something strange on the new rod. The steering box side has a ball joint similar to a tie rod end which moves with a little force, the idler arm end looks slightly different (at the base of the tapered shaft) and does not move. I don't have another sample but can someone confirm if this sounds normal.
Posted on: 2011/5/12 13:01
It sounds common for a worn joint. There should be no side-to-side or up-and-down movement -- just like the other joints.
Posted on: 2011/5/13 2:45
