rocker covers
From Goulburn NSW
Hi guys i would like to pollish rocker covers what do u guys use,paint stripper then a tool on the grinder to buff them but whats it called.
Posted on: 2011/9/18 2:24
Re: rocker covers
From Tamworth , NSW
i can sell ya an already chromed one.
Posted on: 2011/9/18 2:25
Re: rocker covers
From Goulburn NSW
For ca18 how much?
Posted on: 2011/9/18 2:35
Re: rocker covers
From Tamworth , NSW
no for A series.
you didnt specify ca18
Posted on: 2011/9/18 2:36
Re: rocker covers
You should have know pepper, all 1200's come stock with ca's nowadays
Posted on: 2011/9/18 3:53
Re: rocker covers
You can buy a metal polishing kit from Mitre10 and probably Bunnings
that you can use on a drill (it will come with a coarse sisal type wheel and a buffing wheel and 2 types of polishing compounds.
However, you've got to be careful with them as if your not careful the retaining bolt can touch on what your polishing and leave a nasty scratch.
To be honest if you want a professional job, pay a professional. There are always tight spots that need smaller tools to get into and for bigger surfaces a bench grinder with polishing wheels is the go.
If your only ever going to need to get a few things polished it's not worth buying the gear.
Posted on: 2011/9/18 4:52
Re: rocker covers
From sydney
Get a can of crinkle finish, it won't polish your rocker cover but will be cheaper.
Posted on: 2011/9/18 9:09
Re: rocker covers
From Goulburn NSW
Hi guys went down to local hardware and found a metal polishing kit but only has by the looks of it the polishing wheels what do i use to get ride of the paint to start out with.
Posted on: 2011/10/2 8:31
Re: rocker covers
From Gold Coast, QLD, Australia
paint stripper
Posted on: 2011/10/2 8:45
Re: rocker covers
From Adelaide
Soaking it in thinners will also make the paint flake off, a bit gentler than paint stripper.
Edit: Or at least soften it, will take something like days so not fast. I got some very old and hard paint off a bonnet by soaking towls in the thinners I used to clean the spray gun then wrapping it up in plastic.
Posted on: 2011/10/2 9:38
