please explain how to read timing from the timing cover :)
From vic
so i have realised that my engine (A12) runs realy good at full advance 20 degrees at idle at 790rpm and thier is no hesitation off idle like i get normaly with 10degrees let alone 7.5 degrees stated in the manual the engine becomes to shaky and hesitates badly!
so my question why does it run fine at full advance at idle?
also on the timing cover it only goes up to 20 degrees so how do i know how much the full advance is at full thorottle because the white mark moves beyond the numbers and i cant tell what my full timing is!
Thanks!
Posted on: 2011/10/6 5:10
Re: please explain how to read timing from the timing cover :)
From Melbourne, Australia
read the service manual to see how much mechanical advance your distributor has, should be your timing at idle plus the mechanical advance, i think there is little vacuum at full throttle so vacuum advance should not contribute
to have to run at 20 on the timing cover surely indicates your cam or crank pulley or other part is installed incorrectly, that's assuming your motor is pretty much standard yes?
dunno how you have had this much patience with your car, do you drive it every day? mechanic would have found problem in no time and if you find a nice one they will teach you a few things at the same time
Posted on: 2011/10/6 5:42
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
From vic
hi thanks yess the engine is dead stock im preety sure the valve timing is correct because when u rebuild then engine i used the bright link method the car runs fine at 10 degrees btdc but i dont know what the cause of the hesitation is somtimes its thier somtimes it isnt i might take it to some dyno tuner just for advice!
getting it dyno tuned for $70 hour is ridiculous in my opinion and they say a minimum of 3 hours :(
but at 20 degrees the engine wont ping or anything even at full throttle why wouldnt it be pinging with so much advance?
Thanks!
Posted on: 2011/10/6 6:32
Didn't sikyne offer you a tuning session on a couple of occasions? He's got a dyno is his backyard.
Stop fappin' about and take the thing to a pro....
Posted on: 2011/10/6 6:37
By the way $70.00 is really good I think, you should seriously consider that, $210.00 to solve your, 3-4 month long problem is a good deal I reckon.
Last time I inquired to get my car tuned it was $350.00 from the word go, then there was a charge for every hour after the first. All jetting and associated costs were also charged to me.
Posted on: 2011/10/6 6:50
From vic
I took it to 2 mechanics and they were lost aswell they hooked up a fuel mixture gauge in the exhaust and played with timing and fuel mixture and the hesitation still is thier!
Sikyne did offer for a dyno tune but he lives preety far away from me and I havn't got the time at the moment due to coming up vce exams!
i might have to end up taking it to a tuner!
anyone you know close to dandenong that is good at tuning carburettors and this kind of stuff?
Thanks!
Posted on: 2011/10/6 6:53
From Sydney, Australia
$70 is cheap labour for anything these days. And most timing lights should be adjustable so can measure timing when it advances/retards.
Posted on: 2011/10/6 6:54
B110 sedan
From vic
ohh sorry guys i meant to say $95 hour on dyno and $70 tune without dyno which i have already got done but didnt help the hesitation problems!
so one question is most people out thier driving thier datsuns with no hesitation at all off idle? i came to think it was a stock hitachi thing ?
Thanks!
Posted on: 2011/10/6 6:57
From Malaysia
there should be no hesitation anywhere. A is a very smooth engine
Posted on: 2011/10/6 7:36
Not too shy to talk
From Dub-Ya Aye
Do you mean by "hesitation off idle" that when in neutral, idling and you jab the gas pedal, it dies for a split second, then revs out?
Or, when you jab the gas pedal, it splutters, then revs out?
U still got points dizzy?
Posted on: 2011/10/6 13:05
