propane
From Brisbane Qld
Any members had any success With useing propane instead of normal fuel on a A12 or A14 ???
Posted on: 2011/8/8 9:24
Re: propane
From Ballarat Victoria
I think there are plenty of members here that have or do use it.
I used LPG on my daily driven ute for 3 years before i retired it. A15, cam extractors and made about 90hp. Went very well! no probs with valve seat wear, easy to tune, cheap to run. Did about 90,000km`s in those three years too.
Posted on: 2011/8/8 9:35
VIC DYNO HIRE
Re: propane
I've had mild success on a15 with LPG. Similar but different enough to propane. Working better on L16 so far
Re: propane
From Brisbane Qld
Any u guys in Brisy? I think BOC Gass At rockle would sell it. I have A14 with a A15 head on it.
But could get L18 from my mechic. Do i need a drifrent fuel tank lines or carbie jet sise? I have a A12 niky now just drilled out jet to 1.15 ran good at both ends under load and top end. i could buy 28/36 webber
Posted on: 2011/8/8 13:42
Re: propane
It does not use the petrol carburetor. It uses a gas mixer which you either fit over the carburetor or remove the carb and fit.
Read all about Datsun 1200 and propane/LPG with many photos at Propane.
Posted on: 2011/8/8 20:55
Re: propane
From Brisbane Qld
Hay i would like to start up this agine caus fuel is never going to get any cheaper.
Any body interested?
Posted on: 2011/12/8 1:31
Re: propane
Propane is not readily available in Australia- lpg is which is a mix.
A series LPG installs are custom jobs, not many installers would want to do it but if you go straight LPG, easier than dual fuel.
Not every servo stocks LPG- so you may need to plan your trips in advance too, making sure they stock it.
Posted on: 2011/12/8 2:41
Re: propane
LPG can be mostly propane or a propane/butane mix. The systems and installation is the same.
This is not some weird alternative system. LPG is a common system, and was even offered by Nissan from the factory on some models. See LPG.
Dave, if you have specific questions, what are they?
Posted on: 2011/12/8 3:47
Re: propane
From Melbourne,Australia
Im running mine on LPG as well so if you have any questions just ask
Posted on: 2011/12/8 4:55
Re: propane
From Brisbane Qld
ok i think maby i should just wait till i got the cash because i need to fix the A14 thats i in the car now. Maby its just a pipe dream for me
Posted on: 2011/12/8 7:12
