A series engine parts new/used
From sydney.nsw
Got HEAPS of engine parts & things. PM me for any engine bits you many need.time for a clean up. EG; Engine Rebuild Kits A12/14/15, Gaskets/bearings/rings / heads std,ported / cams std,used modified / blocks / cranks / a15 78mm forged flat tops / a15 flat top cast pistons & rod combo /A14 HI comp piston / A12 Flat tops pistons etc.(to must to list)X-race engine parts. etc cheers ernie
Posted on: 2012/3/1 6:01
A.T.E RACE ENGINES: ( " AUST 1 " 2010 ) A15 GO THE DATTOS... 0412 864 741
Re: A series engine parts new/used
From Sydney
Copper a14 head gasket??
Or a strong one?
Posted on: 2012/3/1 9:15
From sydney.nsw
got both.
Posted on: 2012/3/1 9:21
From Perth
What have you got in a 77 or 78mm A15 piston ?
I see 78mm forged flat tops... price and any other options
Need to repiston my old A15 race engine
Can send you the specs if you want to advise on my needs
Will be put into a 1000 for hillclimb and sprint duties and occasional street blats (usually too and from events)
Posted on: 2012/3/1 9:56
From sydney.nsw
pm sent
Posted on: 2012/3/1 10:10
Any webers, slightly chunkier cams for an a12 with an a14 or 15 head?
Posted on: 2012/3/1 11:00
1200 Ute - Mild A12
1200 Ute - Donor Shell Sold
1200 Coupe - A14 EFI SC
From sydney.nsw
pm sent, no webbers, got cams
Posted on: 2012/3/1 11:04
From Perth
Oil Pump ?
Posted on: 2012/3/1 21:53
From sydney.nsw
new ones coming (8-10 weeks)hopefully, i can rebuild them,have heaps of s/hand ones if you need,cheers
Posted on: 2012/3/1 23:02
Quite a regular
From Ballarat Vic
what have you got in the way of hot cams, and a price for one?
Posted on: 2012/3/2 4:19
