Re: dash led bulbs
Type 161 are known here as T10 or T3.25 (3-1/4) "miniature wedge" http://www.donsbulbs.com/cgi-bin/r/b.pl/161.html
#7 - Dash indicator lamps
The round Dash T/S are type 1445 (known here as BA9s "miniature bayonet"), but are low power 1.7 watt. http://www.donsbulbs.com/cgi-bin/r/b.pl/1445.html
They seem bright enough.
Posted on: 2012/5/6 0:24
Re: dash led bulbs
Bummer! These bulbs that I bought are just a tad too long in the bulb. Enough to not fit in the dome recesses in the tacho. I'm wondering if there is any way to make a spacer so the part that clips in sits back a little and allows the bulb to clear? Any one have any suggestions how to do this without fouling the operation of the bulb? Cheers.
Posted on: 2012/5/10 11:12
Re: dash led bulbs
From Adelaide
you could file down the bulb a bit, it's just plastic (acrylic?) You can go almost all the way down to the two bits of metal that hold up the tiny piece of silicone that is the actual LED element.
Posted on: 2012/5/10 11:58
1200 Coupe A15E - ITB
Lamb Daiquiri - a man's cocktail!
Re: dash led bulbs
Cheers Lamb. Can't tell if they are plastic or glass, but without the bulb fully enclosed won't that be a fire hazard?
Posted on: 2012/5/10 12:41
Re: dash led bulbs
Has anyone else run into this problem before? What was the solution? Cheers.
Posted on: 2012/5/30 10:40
Re: dash led bulbs
From Perth WA AUS
Remove the green coloured dome from the tacho then all is good.
These LED's should not produce enough heat to be a fire hazard.
Posted on: 2012/5/30 10:54
Datsun 1200 2Dr sedan.
Re: dash led bulbs
Did you do that on yours Levey? I would have to take apart the whole tacho?
Posted on: 2012/5/30 11:17
Re: dash led bulbs
From Perth WA AUS
I think from memory I used a soldering iron to melt a hole in it. Same result in the end but with different coloured LED's you would want the coloured filter removed anyway.
Posted on: 2012/5/30 11:47
Re: dash led bulbs
Cheers. I'll use my soldering iron to do the same.
Posted on: 2012/5/30 11:54
Re: dash led bulbs
I used these style
Look at this on eBay:
2 X T11 BA9S 4 SMD LED White Light Bulb Lamp 12V T4W
http://bit.ly/KZ7bPl
Or these
White 4 LED T4W BA9S Side Dashboard Light Car Interior Bulb DC 12V
http://bit.ly/L29uFd
Posted on: 2012/5/30 12:01
Car free
« 1 (2) 3 »
