Re: SR20 Swap questions
Not too shy to talk
From South California, USA
oh ok, yeah i see what you did. did you cut any of the tunnel off? because i just cut a square where the shifter goes and it seemed to help a whole lot.
http://imgur.com/UvV3Z
i hope i dont have to cut the fire wall..
Posted on: 2012/6/5 5:41
From MOOROODUC. Victoria
I put an Auto box in so YES the tunnel had to be replaced - even then it was too small
jpg  Naked gearbox.jpg (189.77 KB)
8710_4fcd9aa503a55.jpg 968X648 px
Posted on: 2012/6/5 6:35
Ivan, do you have an auto 1200 tunnel, or the manual 1200 tunnel? Those S14 gearboxes are very long if the shifter area.
Your pic:
Posted on: 2012/6/5 7:33
Yes, needs a different style of exhaust manifold
Posted on: 2012/6/5 7:34
Not too shy to talk
the 1200 was a stick shift so the tunnel is smaller. so i will have to do some cutting i guess. Going to have to suck it up :(
will a top mount give me the clearance to the steering column problem? or just a different manifold?
Posted on: 2012/6/5 14:46
1973 Datsun 1200 Coupe
SR20DET stock turbo.
« 1 (2)
