How to use AE86 LSD in Ute
http://spark88.blog.fc2.com/blog-entry-106.html
Remove differential center, drill holes in flange to fit AE86 center.
Looks like original: 8-bolt. New pattern: 10-bolt
To the AE86 diff bolt in $700 TRD LSD
Bolt in re-drilled H165 housing
Fit tailshaft adapter
and a bonus:
H165 C22 Vanette rear axle assembly
vs
H165 1200 Sunny Truck
Posted on: 2012/11/5 3:18
Edited by ddgonzal on 2012/11/5 4:02:55
Re: How to use AE86 LSD in Ute
New word: nonsuri (non-slip)
must be the latest thing...
Another one for sale, this time an empty housing:
http://page13.auctions.yahoo.co.jp/jp/auction/r95496410
Posted on: 2012/11/5 4:12
I wonder if other Toyos used the same diff centre.
New LSD $349 USD
Posted on: 2012/11/5 4:26
what about tailshaft?? does it bolt up the same?
Posted on: 2012/11/5 4:32
1200 Ute - Mild A12
1200 Ute - Donor Shell Sold
1200 Coupe - A14 EFI SC
From Brisbane
Thats a cool option to have. Got to give people respect who work that stuff out
Posted on: 2012/11/5 4:35
Unknown. There is a photo of an adapter but it may be for using B110 tailshaft with H165 housing.
Maybe someone who reads japanese better could comment on what it says.
Posted on: 2012/11/5 4:41
so axle splines must be the same??? wow if so!
good info DD could help quite a few of us out
as toyota diff centre is about 50 from some wreckers
edit... just had a brain fart!!!!
how about using the 4.9 centres from toyota into a h165!!???
Posted on: 2012/11/5 4:57
Yea axles are the same spline/diamter, Pitroad uses the TRD LSD only in H165 gear carrier
Does the centre have to be from AE86 or are any other Toyotas the same?
Posted on: 2012/11/5 5:00
Ok just found out the ratios are not that good for the T series diff
so from 3.9 to 4.3 available so its measures 6.7 inches unlike non
4age diffs which are usually 6.38 inches on the Ke70 corollas but earlier
celicas and corolla t18 have supposedly the 6.7 inch one which makes them
a hitachi H170 or the same as the Suzuki Samurai, Sierra and Jimny Hitachi
unit so there could be a way to just use the LSD unit and keep datsun ratios?
or probably even better get hold of a Suzuki Samurai LSD centre from a
suzuki specialist in the states and run the suzuki 5.12 from the vitara front
diff centre into the sierra housing or perhpas H165 datsun housing.
Seems HItachi made alot of diffs for different companies but info is scarce
unfortunately however seems like most Banjo style diffs are Hitachi from Jpn
Posted on: 2012/11/5 5:38
No wonder they look so similar.
I'm guessing it is the 6.38 (162mm) diff. Is the gasket match?
Yes, some H165 carriers will take the TRD LSD but the but heads need to be modded or something.
Pitroad sells a kit.
Posted on: 2012/11/5 8:19
(1) 2 3 »
