making webber manifold
From campbelltown (sydney) australia
hey doods, would it be possible for anyone with either a 45 mil webber, or a 45 mil webber manifold to take a measurement of the spacing between the throats, im starting to make all the manifold bits up, and i need this measurement.
Posted on: 2004/4/15 9:39
Re: making webber manifold
From sydney australia
an easier cheat would be to get the gasket that you put between the weber & the manifold.these are available from carby services at burwood,or any reasonable auto shop.these should give you stud spacings,diameters,etc.they are usually from warnerford & look like o rings with a joiner.
Posted on: 2004/4/15 12:12
thats the plan just thought a trip to someones shed with a quick look with the vernier's would be easier than a drive to burwood.
Posted on: 2004/4/15 19:05
All Weber DCOE carbs have 90mm bore spacings. The mounting bolts are at a 16-degree angle (angled in at the bottom, out of the top). The bolt holes are 72mm apart, with 8.5mm hole size.
Posted on: 2004/4/18 5:02
thanks ddgonzal, ive taken ur specs and made a diagram im pretty sure its correct it just looks very big when on paper, just need to find a pic of the outside shape then i can make this part as well.
Posted on: 2004/4/18 8:37
From GOLD COAST AUZ
I have the book on all WEBBERS made.I have been lookin for it for 2 days for you so i can post a pic of the shape and size of it. Stay tuned to this site.Wife is going to tidy up side shed I think it is in there.Any other base plates pic needed let me know.
Posted on: 2004/4/18 8:55
rather be a old fart than a young d##khead
thanks holeshot, yeah just needed a pic of the outlet side of the weber, but as ddgonzal gave me some specs ive made a drawing and i think its just about right.post a pic anyways if u have time, i dont know what shape the carby plate is so thatd be helpful when making this, thanks mate.
Posted on: 2004/4/18 9:00
