Urgent help
From Trinidad and tobago
i have s13 brake modification complete i followed all the steps but my 13'' wheels wont fit.What should i do?
Posted on: 2012/12/12 2:18
'71 Four Door Sedan.
Street Sleeper!
STILL LIVIN' THE 70'S LIFE !!
Re: Urgent help
From Melbourne, Australia
explain why they don't fit (hitting in the diameter or on the front face) and if you are using steel or alloy wheels, it's not uncommon to gring some material off the back of the caliper to make clearance
Posted on: 2012/12/12 2:28
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
Re: Urgent help
Even better are they 250 or 280mm rotors. The larger won't fit under 13's
He uses 13 inch super light style rims rc
Posted on: 2012/12/12 2:45
Re: Urgent help
Thanks for the feedback guys,i have longer studs to install so when im done i will know better.
Posted on: 2012/12/12 3:17
Street Sleeper!
Re: Urgent help
I i fit spacers will it help it form hitting the front of the caliper?
Posted on: 2012/12/12 23:27
Street Sleeper!
Re: Urgent help
We don't know. 13" wheels are all shaped a little differently. S13s used larger wheels.
Posted on: 2012/12/13 1:10
Re: Urgent help
take some pictures of where its hitting. Spacers may move the inner welds or lip of the rim further away from the calipers. It depends on manufacture and offset of rim.
see how on the inside the rim tapers towards the face of the wheel
Posted on: 2012/12/13 1:37
Re: Urgent help
Hey hey
In having the same problem.
Just mocked together the brakes on some spare struts to see if they would fit over my newly acquired ssr mk's 13x7j
The hit on the caliper on the following place. I chalked them to find out. I'm planning in running a small spacer but filing the caliper did come to mind
Posted on: 2012/12/13 4:59
1200 coupe
Re: Urgent help
My rx7 stuff has been shaved down to fit 14's over them, you are able to take a small amount off of the callipers and as people have said it depends on wheel style and offset
Posted on: 2012/12/13 5:53
Car free
Re: Urgent help
My problem is that i have found out that i have the wrong s13 disc.I need the smaller ones..
I have also reverted to my original b310 setup today.im rooling for the while now.
Posted on: 2012/12/16 3:18
Street Sleeper!
