Ca18 valve removal
From Goulburn NSW
Hi guys i would like to know if anyone has any tips on how to remove the valves as i dont have the valve removal tools.Tried g clamp,didnt work,tried socket with hammer and block off wood,didnt work,any tips,much appreciated.
Posted on: 2013/1/26 2:53
Re: Ca18 valve removal
Is the cylinder head off the engine?
See Remove Valve Springs, which is for the A-series but might give you some ideas.
Posted on: 2013/1/26 2:56
From Goulburn NSW
Yes the head is off the motor.Ok i have used a g clamp with a socket it has compressed the valve spring but still wont release,what do i do next?
Posted on: 2013/1/26 4:13
Under the socket you find find the valve keepers. Remove those and it will all come apart.
Posted on: 2013/1/26 4:51
From Goulburn NSW
Hi DD,one problem the socket is there.
Posted on: 2013/1/26 4:57
That's why a socket is not used. Did you take a look at the guide?
Posted on: 2013/1/26 6:40
From Sydney NSW
I could write a book on this- spent two days doing it without any special tools. Get a large spark plug socket to sit around the stem and collets and hammer it on the retainer (preferably with a cloth around the socket to stop flying collets). If the collets don't pop out you aren't hitting it hard enough, short sharp blow. Make sure the head is positioned so valve itself wont hit your bench while moving or you could bend a valve. After a little practice you should be able to do it with only one or two whacks of the hammer. Do it in a clean environment so you don't lose any collets, I doubt anyone will sell you one by itself. The order of the valves and collets in their original place is not important, you can mix and match (but not mix exhaust or inlets valves obviously)
Re-Installation is a little more difficult and requires a lot of patience, I will detail this after work if you want.
Posted on: 2013/1/26 7:21
Or just buy, rent or borrow a valve-spring compressor. I paid $25 for mine.
Posted on: 2013/1/26 7:42
From MOOROODUC. Victoria
see what this guy did with an old socket and a big G clamp
http://www.d-series.org/forums/diy-fo ... pring-compressor-0-a.html
Posted on: 2013/1/26 9:08
From Sydney NSW
No a valve spring compressor wont work, the valves are recessed to far into the head. That method of removal requires a magnet as well, and if the collets become magnetised it becomes a real pain. just bang them out.
Posted on: 2013/1/26 11:48
