wanted stage 3 head
Quite a regular
From Gold Coast
hi everybody i'm chasing a worked or oval port head.
Posted on: 2013/2/18 7:38
Re: wanted stage 3 head
From sydney.nsw
got some, depending on your budget / all different stages,cheers. pm me if interested
Posted on: 2013/2/18 7:58
Edited by bige on 2013/2/18 22:04:12
A.T.E RACE ENGINES: ( " AUST 1 " 2010 ) A15 GO THE DATTOS... 0412 864 741
ask levey he loves giving head around the place.
Posted on: 2013/2/18 12:48
From Snohomish, WA USA
Ha!!
Posted on: 2013/2/18 16:02
'73 2 Door Sedan
Crower Stage 3 Cams/SS Valves
Forge CP Pistons/ Eagle Rods
Ford 8.8/Mini Spool/4.11
From Brisbane Qld
You two funy buggers I have a motor that has a Wade stage Three cam how
could i tell if its a stage three head and then i might sell?????
Posted on: 2013/2/18 18:13
What does "stage 3" mean? You'd have to ask Wade.
Probably means is revs up to 8500 RPM. So take your stock H89 head and put dual valve springs on it. And then rev the engine up when you drive it.
Posted on: 2013/2/18 19:10
Quite a regular
From neerim east victoria
AS far as I know
stage one ----matched ports/minor combustion chamber polish
stage two ----polished matched ports&combustion chambers modified & double valve springs
stage three---- as above with larger valves/full polish/ enlarged ports cc'd & flow tested
as for cams there is realy no stage 1-2-3 ect as ther are hundreds qf different grinds to suit all types of aplications-rev ranges torque curves ect, the terms stage 1-2-3 came about in the early 60's when here in Australia every young bloke was fitting twin carbs & extractors and wanted a cam to suit so when they went to a speed shop they were sold a "stage one"triple carbs minor head work got a "stage two" bored out/fully mod head/balanced ect got a "stage three"as this way the shop only had to stock three grinds for the most common motors ie:holden/ford/bmc
in Wade cams if I rember right the 104 was stage1-113 stage2[most common for usable street use] 121 stage3 you then went to some very wild grinds for drag racing/hill climb/circuit racing,you can get a cam ground for any aplication you just have to let the suplier know exactly what mods have been done and what you want the rev/torque carictaristics to be
Russ [ex Wade cam grinder]
Posted on: 2013/2/18 21:31
Good, that matches the general description of Stage 1, Stage 2 and Stage 3 as used here in the USA.
Wade lists #104 and #113 on their web site today. Based on the specs, their Stage 3 might have been one step above a GX cam (4000-6500 RPM use?)
Posted on: 2013/2/18 22:00
From Brisbane Qld
Yeah great thanks guys What happed to this guy Wanting a Head Hope we havent pissed of pal??
Posted on: 2013/2/19 14:36
how could i tell if its a stage three head
Well if it is a GX head or a worked H89 head, I'd call that Stage 3.
If it is a plain oval port head, sell it to him
Posted on: 2013/2/19 20:18
