Diff shortening
From Narellan,Sydney
People have stuffed me around a bit so decided to cut others out :) going to shorten my diff myself.any one have some hot tips? Other then keeping it straight
Posted on: 2013/4/18 8:50
Re: Diff shortening
From Goulburn NSW
Hey mate did u try street car fabrications I think they are in Narellan,ive talked to them and the seem pretty genuine.Or maybe JC racing in Botany,thats who is doing mine.
Posted on: 2013/4/18 9:20
Re: Diff shortening
Yeah I'm mates with scf.hes a good bloke.hes pretty booked out.iv got no dramas doing mine looking forward to it and going to save me $1500
Posted on: 2013/4/18 9:31
All stainless steel-mild steel Sheetmetal and tube work
All types of welding
Custom metal polishing
BSA custom fabrication 0415 904 474
Re: Diff shortening
From Nyngan, nsw Australia
yeah keeping it very straight is important, i had mine done professorial but o watched it from start to finish, they sleeved it and made sure it had a V both tubes when butted up, for that strength, what type of diff your shorten?
Posted on: 2013/4/18 22:40
living is good,.....
Re: Diff shortening
Made sure it had a V ... what does that mean?
Posted on: 2013/4/18 22:45
Re: Diff shortening
grind a 45 down on both tubes and that creates a V, even you D would understand that :)
Posted on: 2013/4/18 22:56
Re: Diff shortening
From Goulburn NSW
I think they are talking about a v for welding.U weld in that v for more penertration of the join.
Posted on: 2013/4/18 23:23
Re: Diff shortening
It's a hilux diff.and yes of course I will chamfer it.only way to make it strong
Posted on: 2013/4/19 0:22
Re: Diff shortening
Thanks. Got it, chamfer for a butt-weld.
* Shorten the axle tubes and weld them
* Get new custom-length axles ($800/pair)
* Drill the axles for the desired wheel bolt pattern
* new bearings for the new axles
* Cut and reweld (or add) spring plates
Posted on: 2013/4/19 1:49
Re: Diff shortening
Datrotor you can go De Dion using Volvo 360 de dion tube and volvo shafts and 300zx brakes then run an R200 they are 7.8 inches and $100 then just worry about shortening cv or axles much easier in every way to source and better setup.
Posted on: 2013/4/19 2:27
(1) 2 3 4 5 »
