short stroke shocks for 1200 ute??
Looking into re-doing my rear suspension setup to get rid of my lowering blocks whilst still being low.
Going to be reseting my leafs with the reverse eye main leaf aswell as adding a new leaf to stiffen it all up.
Now this is where im unsure of whats a direct bolt in for some short stroke shocks. Has anyone had experience with the suzuki seirra shocks? I have heard they work but not 100%. Open to all opinions guys
cheers!
Posted on: 2013/4/24 4:10
MUNCH MUNCH PISTONS FOR LUNCH
Re: short stroke shocks for 1200 ute??
I think in sedans you can use vs commodore Ute ones with a new bush and ferral pushed into it. See if it may work in a Ute.
Posted on: 2013/4/24 4:39
From A-TOWN
I think on beeoneoneoh he had a write up on rear end setups, cant seem to find the page anymore, maybe someone can post the link as i am also keen as to slam the sheiiat outta my ute and still want decent travel. I think some people have ran VW shocks but not 100% sure.
Posted on: 2013/4/24 9:58
From Brisbane, QLD
Posted on: 2013/4/24 10:12
71 B110
Thanks jacob! But there isnt really an option there other than 1 but the shock is really soft.
anything else?
Posted on: 2013/4/30 15:14
Vw rabbit shocks are most common for 1200/120y struts about 65mm shorter than stock
Posted on: 2013/4/30 15:29
Car free
yeah already got those for the front.
after something for the rear
Posted on: 2013/5/1 4:59
I'm doing the exact same thing to my 1200 Ute at the moment. What year rabbit shocks? Much fiddling to fit? I'm getting my leafs reset this week too so I'm keen to find a pair for the rear.
Posted on: 2013/5/3 11:15
Front: see Strut Insert Part Numbers under "VW" sections
Posted on: 2013/5/3 21:56
Rear: You only need shorter-stroke shocks if the originals are riding fully compressed.
With reset leaves, would short-stroke shocks really help? Or just cause the tyres to rub when going over bumps?
If you cut down the ute spring bumpers, then you *may* need shocks with shorter compression length. But maybe not, has anyone actually measured it?
Posted on: 2013/5/3 22:29
