Thanks Chris for the Electronic Dizzy Kit.
From sydney australia
Just would like to publically thanks Chris Lyons for organising that bulk deal on the dizzy kit. Got mine last Thursday, installed it Friday, no real problems except the timing kept retarding back to Zero. This was because the plastic bit on the dizzy shaft wasn't all the way down, due to the front screw having an earth wire under it. As this earth wire is for the points it can probably be removed, but I moved it to the other screw, just in case it was necessary. This allowed the plastic sleeve to sit down further & now it has stopped retarding the timing.
I then found out the muffler had collapsed & was choking the motor. So I was forced to fit some extractors & a 1 & 3/4 inch exhaust system I had in the shed. Much better.
Posted on: 2013/8/20 11:13
Re: Thanks Chris for the Electronic Dizzy Kit.
Absolutely no problem whatsoever. Thank you guys for the support.
Yes, regarding the fitment, the black collar must be installed all the way down over the cam lobes of the shaft.
Posted on: 2013/8/20 22:06
From Sydney, NSW, 2036
Received my kit too thanks Chris,
Thanks B310gx for the install tips, should be doing mine soon.
Posted on: 2013/8/21 0:11
81 Datsun ute
The detail is the black collar, do not force it but pay attention to the cam lobe alignment with the impressions in the collar.
Thank you Paul for identifying this, I also had an issue with this:
jpg  image.jpg (127.48 KB)
7952_52146b4c1518f.jpg 1000X666 px
jpg  image.jpg (114.24 KB)
7952_52146bbfe0d20.jpg 1000X666 px
Posted on: 2013/8/21 8:27
From Perth WA AUS
I can verify that at 8000 rpm these still work beautifully ( just make sure your flywheel bolts are properly torqued) :(
Posted on: 2013/8/21 11:23
Datsun 1200 2Dr sedan.
Fitted mine up yesterday. Only takes 10 mins. Works perfectly !!! Once again thanks Chris
Posted on: 2013/8/21 12:37
From Sydney, NSW
does it use the stock dizzy and coil?
Have any more Chris?
Posted on: 2013/8/21 14:49
Hot-Spark Ignition uses the stock distributor. It can use the stock 12V coil with ballast resistor OR you can fit a high-energy EI Coil without ballast resistor.
The units chris is suppyling appears to be the same units as what Hot-Spark sells.
Posted on: 2013/8/21 22:07
Hot spark sells the same units as me!
All those big companies throw their name on the product and sell them for a mint. Mine are quality assured with no name packaging and of course, much cheaper.
Posted on: 2013/8/22 1:06
From Mordialloc Victoria 3195
Another asking if you have any more for sale ?
Cheers David
Posted on: 2013/8/23 8:25
