Re: A14 Performance
From sydney.nsw
I sell Engine Rebuild Kits for A12/14/15 engines on here,also H/P cams,double valve springs ,and have heaps of A series engine parts,ported heads,cams,engines,etc.(NOTE; I CAN DO A HIGHER COMPRESSION PISTON FOR A14's)
if your interested, I could Help.
cheers Ernie 0412 864 741
(I'M IN SYDNEY,CAN POST ANYWHERE).
Posted on: 2013/10/13 21:26
A.T.E RACE ENGINES: ( " AUST 1 " 2010 ) A15 GO THE DATTOS... 0412 864 741
Re: A14 Performance
From Las Vegas USA
If your budget will swing just buy a cylinder head already done up. If not clean up the ports on your existing I'd go with something mild like the GX cam or close to it. On the flywheel you have a couple of options but for street I would not run anything lighter than 14lbs.
Mild porting, Cam, 32/36 and extractors should get you about 15 hp give or take a few. One thing to remember is that the more you mod an A-series the higher up the rev range the power band goes and the standard gearbox starts to become an issue due to the huge RPM drop between gears. It's best to give up a little so that the drivability doesn't suffer
Tom
Posted on: 2013/10/14 4:22
Re: A14 Performance
From Launceston, Tasmania
Thanks guys. I reckon I'll port n polish it, mild cam, electronic ignition, 32/36 weber and extractors into a 2 inch system.
Thats probably about it. Cheers for all your helpful comments.
Posted on: 2013/10/14 9:32
Re: A14 Performance
Good luck with the build. Post pictures! In fact start a build page in Project Builds section.
Posted on: 2013/10/16 1:26
« 1 (2)
