datsun gx coupe project
Not too shy to talk
Hi .... i am michael papachristoforou.
I need some help on my project..
I have discover some rust on the floor when i removed the stone chip from the floor.. the rust went through the floor and a pice of the suspention!!!! i need some help (tips) on reparing it tanx !!
jpg  1382975509853.jpg (85.82 KB)
17145_526e892c427c7.jpg 200X325 px
jpg  1382975506290.jpg (81.15 KB)
17145_526e894a78ef7.jpg 200X267 px
jpg  1382975501660.jpg (54.82 KB)
17145_526e896b0c364.jpg 200X150 px
Posted on: 2013/10/28 15:09
Edited by michaelpapa on 2013/10/28 15:57:38
Re: datsun gx coupe project
Cut and weld is the solution. Use high strength steel sheet metal as Datsun used originally
Posted on: 2013/10/28 17:43
Not too shy to talk
ok how must i make with the suspention part on the botom.. some one told me i must just clean it with a wire brus on a grinder and then fiber glas over the hole floor to about 5 mm thick.. ?
Posted on: 2013/10/28 19:23
Much better to cut the rusty parts out. Then weld in new metal.
Posted on: 2013/10/28 19:37
Not too shy to talk
Ok so what thickness of steel do I need to use and what welder do you prefer
Posted on: 2013/10/28 20:08
Not too shy to talk
Hi I am back again an have some more questions. ? Can anyone identify what kind of differential I have on my gx .?
jpg  rps20140828_103945.jpg (73.23 KB)
17145_53feeb2c0f867.jpg 800X600 px
jpg  rps20140828_104012.jpg (50.02 KB)
17145_53feec0a9ddfa.jpg 800X600 px
Posted on: 2014/8/28 9:45
From sydney australia
Borg Warner rear end, as used in 1976-78 120Y sedans. They are the same width as the 1200 diff & somebody in the past has replaced your original H145 diff. I bought a 1200 coupe for parts in 1985, mainly for the A12 5 speed & it had one of these in it. Drove the car home then wrecked it out, cause the repair list to get it registered was 2 foolscap pages long. it was dark green with a vinyl roof. Long time past.
Posted on: 2014/8/28 11:02
Not too shy to talk
Okok is it a better (stronger) diff than the h145 ? ? What is the difference.?
Posted on: 2014/8/28 11:56
Not too shy to talk
Some before and after photos of my engine bay..
jpg  rps20140828_201719.jpg (75.92 KB)
17145_53ff74e3b1a23.jpg 800X600 px
jpg  rps20140828_201804.jpg (53.78 KB)
17145_53ff750ec45f5.jpg 800X600 px
jpg  rps20140828_201859.jpg (40.43 KB)
17145_53ff752932b96.jpg 600X800 px
Posted on: 2014/8/28 19:31
Looks like you're slowly getting there. Good work with the restoration so far.
Oh and the Borg Warner rear axle is stronger than the standard h145. Its about the same strength as a h165 apparently.
Posted on: 2014/8/28 21:55
