Re: rocketrod's 1200
From MOOROODUC. Victoria
no probs
Mine is an '81 model so I think I am in a different boat
Posted on: 2013/1/25 0:07
From Nyngan, nsw Australia
little help fella's, ive asked about this back in my thread, ive purchased a MadDat speedo cable for my ca convo,
ive removed the electronic ca drive to replace for the analog drive,
now is there a larger gear drive to suit the ca box (see pic for different size) with datsun drive the gear is fixed to the shaft & smaller where the ca is removable & larger,
my Q is are the bigger gear available for datsun ?
Posted on: 2013/4/2 11:31
living is good,.....
From Brisbane
just looking at my maddat cable. that black cap comes off and threads onto the datsun end. I remember someone telling me bluebird gear. could be way off tho. Car looks great btw : )
Posted on: 2013/4/2 11:46
From Armidale N.S.W
Couldnt you just swap them ( the shaft) over i see a collar/split pin or whatever there called in the main body which as you would know you have to squeeze a bit shut to remove and the shaft should drop out and then swap it over.
Posted on: 2013/4/2 11:47
73 1200 wagon SOLD
datsun is fixed where ca does have a C clip able to remove, pretty sure bluebird are the same as datsun
Posted on: 2013/4/2 11:50
From Armidale N.S.W
Whats the one on left out of Model ? 4 or 5 speed ? Pretty sure any L series, five speed speedo input will fit in that box and work. Even VL commodore and R31 speedos should work From memory my VL had manual/cable speedo drive not electric.
Posted on: 2013/4/2 12:04
73 1200 wagon SOLD
yeah L series drive on the left, ok il look into those other drives
Posted on: 2013/4/2 23:33
Posted on: 2013/11/13 20:41
Caltracks nice
Posted on: 2013/11/13 21:04
Are these legal on aus roads?
Posted on: 2013/11/13 22:40
« 1 ... 14 15 16 (17) 18 19 20 »
