Timeing case cover?
From Brisbane Qld
Would the timing case cover From A14 Be the same as a A12.
Posted on: 2014/2/3 22:32
Re: Timeing case cover?
Yes. Except early A12.
Posted on: 2014/2/4 0:06
From Brisbane Qld
Yes its Early A12 block I have so do I need from that Block or later A12 will do
Posted on: 2014/2/5 7:31
The block makes no difference
The pre 1972 timing cover has one timing mark. Post 1972 has multiple marks. Doesnt matter if its A12 or A14.
Posted on: 2014/2/5 8:01
From Brisbane Qld
Ok thank u David.
Posted on: 2014/2/6 1:03
so timing marks only the difference? wow David thats clinical!
Posted on: 2014/2/6 1:55
From Brisbane Qld
The only one have other than the A14 is On the motor in the car now which is
another A12 from 1980 sunny.
Will that do?
Posted on: 2014/2/7 4:44
Posted on: 2014/2/7 5:28
Dee, here's on for you: the other timing cover is early A10 which only fits the single-roller chain. The A10 double-roller cover was used for first couple years of A12, then the new style cover was used circa 1972-2010.
Hmm that gives me an idea for shaving weight off an A12 ...
Posted on: 2014/2/7 5:37
From Brisbane Qld
What's the go Guys the one of the 1980 engine be ok?
Posted on: 2014/2/7 11:08
