Alternator swaps
G'day gents,
Looking to buy a new Alternator for my A12 Ute. Have trawled through the tech wiki but didn't find the answer I was looking for. All of the information contained in the tech wiki seems only to be related to US and Japan models with respect to availability of Alternators.
I have the 1974- Later A12 with the Alternator mounted high up on the driver side. Looking for a direct replacement with an Internal Voltage Reg. Is there a Bosch or similar Alternator with these requirements that will bolt straight up without any mods?
Cheers,
Joey.
Posted on: 2015/3/31 12:28
Re: Alternator swaps
From Melbourne AUS
i could be wrong but im pretty sure the 120y alternator was the same mounting but with internal reg?
Posted on: 2015/3/31 12:47
1973 B110 A12
From melbourne
You can use a alternator from a xf ford falcon
but it requires small mods to wiring and mounts
All u have to do is cut the bracket on the engine to suit alter nator
And buy a slightly longer v belt
Then wire uP
Very easy to do
Posted on: 2015/3/31 13:05
Can anyone confirm what Ange has suggested? Where can I find part numbers for Bosch alternators?
Posted on: 2015/3/31 13:14
Only Datsun one listed in Bosch Catalogue is the BXD1242A and that has an External Voltage Reg and following specs:
Specification
Voltage:12V
Amperage:50Amp
Mount Top-Bottom Hole:175mm
Mounting Hole:8mm
Adjust Mount Hole:8mm
Inside Leg Measurement:80mm
Mounting Type:Twin Leg
Pulley:1A
Pulley Diameter:74mm
External Voltage Regulator
Posted on: 2015/3/31 13:35
Which model does 120Y come with? Hitachi LT-150? The locally produced sedan may have a local alternator, while Japan-built coupe may have another.
If so then certain 1980s Nissan alternators will fit. Maybe even 1980s Subaru.
Posted on: 2015/3/31 22:08
Our Tech article says
Alternator
Late 120Y Australian assembled have a Lucas single wire internally regulated alternator.
Lucas 15AC missing F terminal (indicating internally regulated)
Posted on: 2015/3/31 22:36
Gnmm. Looking for a brand new direct replacement though
Posted on: 2015/3/31 23:27
Ute uses same alternator as 1200 coupe, sedan, wagon.
Nissan part number 23100-B9810 bolts up directly with no mods. HOWEVER the wiring requires simple mods.
http://google.com/search?q=23100-B9810+site:au
Posted on: 2015/3/31 23:58
I don't think those are available here in Oz so I'm looking for an alternative aftermarket option.
Posted on: 2015/4/1 0:29
(1) 2 3 »
