« 1 ... 9 10 11 (12) 13 14 15 ... 49 »
Re: Turbo EFI A12 for under $1200. Discussion thread
From Creswell, Oregon USA
D that looks like a 36 tooth chain sprocket.
Do those work like trigger wheels?
Posted on: 2015/4/4 3:10
An idea doesn't work unless you do.
Instagram @MD_Machine
Parler @MDMachine
After more thought...
To keep the focus on Turbo EFI A12, it would be simpler to retain the standard distributor. There is no need to use crank trigger. You can still do programmable spark curves without it. Works with EI distributors too.
Posted on: 2015/4/4 4:11
From Adelaide, Australia
Is there anyway of fitting the sensor and trigger to the dizzy cap and rotor? Not sure if its preferred but it's a different thought :\
Posted on: 2015/4/4 6:21
parts needed: GX air filter box. for sale, stanza steering wheel, 1000 gloveboxes lids
From Kelmscott Western Australia
Seen e15t dizzy in a A15 it used multiple coils here in perth
Posted on: 2015/4/4 6:49
71 Datsun 1200 ute with A14 fuel injection and T50
59 Morris minor ute with A15 fuel injected with intercooled turbo
You can use the standard 1200 distributor with multiple coils. MicroSquirt 2 can fire two GM V6, or one AUS LTD coil pack, or a Mitsu coil pack, etc.
Posted on: 2015/4/4 8:59
Edited by ddgonzal on 2015/4/4 20:10:30
If it's somewhat simple, and efficient.. I'm ready to see it.
I got my Hyundai 40MM TB, 2-500cc injectors, or 4-275cc's, 2 different superchargers to try, and my CNC on the ready.
Posted on: 2015/4/4 16:01
Parler @MDMachine
Yes, sikyne will make it relatively simple.
Turbos are the most efficient. Blowers take HP to drive but turbos are basically free HP. Its why almost every automaker in 2015 is using turbos to meet fuel economy and emissions targets. From Ford's EcoBoost to Ferrari's "no more NA engines".
Posted on: 2015/4/4 20:45
I got a turbo but the USA cars have zero room on the flow side of the engine.
Posted on: 2015/4/4 22:26
Parler @MDMachine
matto1kute-
i have an sr20 cas adapted to a12 dizzy shaft
Posted on: 2015/4/5 10:26
www.datsun1000.com
Current Dato -
68 B20 ute
Previous Datos -
ca18det 1200 ute 180rwkw
Stocko 1200 wagon
for the Napoleon sided road cars maybe an idea
to look at this this kind of tight manifolding?
https://www.youtube.com/watch?v=dskutHwOy7U
just watch the goaty/beard on propellor
Posted on: 2015/4/5 16:01
