120y coupe widest tyres
From Penrith, Sydney, NSW
Can anyone tell me what the widest tyres are that will fit on a 120y coupe. Will 185/70R14 fit?
Trav
Posted on: 2015/5/26 12:19
"If the doors of perception were cleansed, every thing would appear to man as it is......infinite"
Re: 120y coupe widest tyres
Yes.
Posted on: 2015/5/27 0:36
From Brisbane, Australia
185/70 R 14 is WAY too tall for a 120Y. Will probably foul stuff when turning and over-gear the poor little thing
Posted on: 2015/5/27 5:40
From Central coast NSW
55 or 60, but 60 will be easier to find
Posted on: 2015/5/27 6:06
185-195/60R14 is a good size for them
Posted on: 2015/5/27 6:24
Edited by L18_B110 on 2015/5/28 0:24:40
185 doesnt fit anyway due to offset. Going to go 175/60 and cross my fingers i havent just wasted $300.
Trav
Posted on: 2015/6/1 0:55
I have run both 175 width on my B210 and 185 width on my 1200 stock body. The B210 has as much room.
Posted on: 2015/6/1 2:00
Damn too much positive offset....back to the drawing board.
Trav
Posted on: 2015/6/2 1:08
Are you using FWD rims? Stock offset is +30 and will properly locate 175 wide tyres, as long as the rims aren't too wide.
If you go very tall then you run into other problems as previously noted. Stock 120Y diameter is 21.7". Factory A14-powered B210 diameter is 22.8". And 175/60R14 is shorter than that at 22.3".
Posted on: 2015/6/2 1:55
I was told they were pintara RWD chasers. I measured the offset and they are +45 so yeah i was told the wrong thing and must be FWD.
Trav
Posted on: 2015/6/2 2:51
(1) 2 3 »
