Re: 1971 Datsun 1200 (B110) Alternator Conversion?
From Snohomish, WA USA
From what I remember since this was done years ago on my car.
Isolated pin on alternator with 10mm nut should be an #8 gauge wire to battery. Small pin on alternator with 8mm nut (I think) is ground. 2 pin plug should have white-red wire which should go to the idiot dashboard light. Last one, which is either white or red is connect to 12v which will give you a reading on a voltage gauge if you have one.
You should be able to just unplug the external voltage regulator and leave it or remove it. Rap up the plug with electrical tape or work your way into the wire bundle and remove it.
Easy.
Posted on: 2017/11/17 0:47
'73 2 Door Sedan
Crower Stage 3 Cams/SS Valves
Forge CP Pistons/ Eagle Rods
Ford 8.8/Mini Spool/4.11
Subject Poster Date
     1971 Datsun 1200 (B110) Alternator Conversion? rgjt405 2017/11/17 0:11
       Re: 1971 Datsun 1200 (B110) Alternator Conversion? datsa73 2017/11/17 0:47
         Re: 1971 Datsun 1200 (B110) Alternator Conversion? rgjt405 2017/11/17 1:45
           Re: 1971 Datsun 1200 (B110) Alternator Conversion? ddgonzal 2017/11/17 4:03
             Re: 1971 Datsun 1200 (B110) Alternator Conversion? ddgonzal 2017/11/17 4:39
               Re: 1971 Datsun 1200 (B110) Alternator Conversion? ddgonzal 2017/11/17 4:45
                 Re: 1971 Datsun 1200 (B110) Alternator Conversion? rgjt405 2017/11/17 5:03
             Re: 1971 Datsun 1200 (B110) Alternator Conversion? rgjt405 2017/11/17 4:40
         Re: 1971 Datsun 1200 (B110) Alternator Conversion? datsa73 2017/11/17 5:24
           Re: 1971 Datsun 1200 (B110) Alternator Conversion? ddgonzal 2017/11/17 5:56
       Re: 1971 Datsun 1200 (B110) Alternator Conversion? rgjt405 2017/11/17 19:56
       Re: 1971 Datsun 1200 (B110) Alternator Conversion? rgjt405 2017/12/31 2:31
         Re: 1971 Datsun 1200 (B110) Alternator Conversion? ddgonzal 2017/12/31 2:55
           Re: 1971 Datsun 1200 (B110) Alternator Conversion? rgjt405 2017/12/31 4:08
             Re: 1971 Datsun 1200 (B110) Alternator Conversion? ddgonzal 2017/12/31 6:06
               Re: 1971 Datsun 1200 (B110) Alternator Conversion? rgjt405 2017/12/31 17:21
                 Re: 1971 Datsun 1200 (B110) Alternator Conversion? ddgonzal 2017/12/31 19:54
                   Re: 1971 Datsun 1200 (B110) Alternator Conversion? rgjt405 2017/12/31 20:10
                   Re: 1971 Datsun 1200 (B110) Alternator Conversion? rgjt405 2018/1/1 18:56
                     Re: 1971 Datsun 1200 (B110) Alternator Conversion? rgjt405 2018/1/19 1:13
                       Re: 1971 Datsun 1200 (B110) Alternator Conversion? ddgonzal 2018/1/19 4:25
       Re: 1971 Datsun 1200 (B110) Alternator Conversion? rgjt405 2018/1/19 4:42
