Does this diff look worn?
Does this diff look overly worn?
The ring gear is strangely worn on the outside, and the drive side teeth look like they have shallow wear. Bit hard to tell from a photo, but what do you think?
jpg  diff.jpg (94.27 KB)
7711_5da56f48951d3.jpg 1200X900 px
Posted on: 2019/10/15 8:03
Re: Does this diff look worn?
Posted on: 2019/10/15 8:38
Edited by unfamilia on 2020/3/29 11:48:35
did you clean it? could be just machine marks from factory
I had some like that and if you look at the teeth gears
you can see very sharp corners rather than round.
Wear prob is no issue by what I can see.
Posted on: 2019/10/15 9:18
Looks like alumi H165
What I would do is put some blueing on the teet and spin it around for a test pattern
Posted on: 2019/10/15 9:29
Thanks all! It's an H150 4.1.
Posted on: 2019/10/15 11:52
