Re: Webber 32/36 DGAV Base adaptor for A15?
From Burbank, CA
well i'm about 1/2 way done making it. I could probably do better with more tools, but with a chop saw, and a drill press and a dremel and some files it's ok. I'll try to include a pic of my progress. If anyone wants a file that will make a template for making one I have one i made in illustrator and seems to be working well for me.
Posted on: 2004/7/15 5:43
From Burbank, CA
the madness continues....
tonight I cleaned up everything. I need to get a metric tap for the carb studs and it's basically done.
Posted on: 2004/7/16 6:32
I simply used standard non-metrics studs, saved trip to buy a new tap ...
Posted on: 2004/7/16 6:48
From Burbank, CA
So ddgonzal , how do you like your DGxV carb?
Posted on: 2004/7/16 7:04
From Burbank, CA
I WIN!!! made the adaptor got the carb mounted, havked a throttle linkage, kindof tuned the carb. I probably need different jets.
yeah, lost bottom end, gained topend.
Posted on: 2004/7/17 4:45
From Wellington, New Zealand
I have also fitted the same webber to my a15 but i am wanting to know if you have sussed the jets on yours as I cant get mine to run properly!!! can you pm me with some info mate!!
Posted on: 2004/7/17 6:48
From Burbank, CA
i need to tune it / get it tuned. It currently idles too fast, but i got it somewhat tuned. Different jets are needed. It's driveable, I have to see if i can tune the pinging at partial throttle or if i need 91 octane.
I followed the information found in the engine tech section here and by following the instructiions on the weber site.
Posted on: 2004/7/17 7:00
From Wellington
Thats one ugly adaptor....did it work
Posted on: 2004/7/26 11:39
From Burbank, CA
it did! yeah it could be made better, but it works.
Posted on: 2004/7/26 16:40
|||\ 81 KPB310 /|||
« 1 (2)
