head lights
From Adelaide, SA the drift state
hey guys i just got a 1200 ute 2 months ago and alreadly had to replace the headlight fuse twice and i is stuck on high beam. even when i have it on low beam it doesnt work unless u hald it all the way back and it goes down to loiw beam when i use the lef indicator im stublled anyone had a problem simliar to this
btw its an 82 model
Posted on: 2005/10/9 6:17
Re: head lights
From Campbelltown N.S.W Australia
check ur headlight relay see if its working...should make a click when u go from high 2 low beam...
Posted on: 2005/10/9 13:08
Re: head lights
na theres no click and could that be a reason for the fuse dying al the time
Posted on: 2005/10/9 14:27
Re: head lights
could be...you are going to have to buy one from a spare parts shop...
Posted on: 2005/10/9 15:26
Re: head lights
I cant be certain about late model utes, but early 1200's dont click because they dont have headlight relays.
Fuzes only burn because of dead shorts.
Sounds like your high beam/ indicator switch is messed up.
Posted on: 2005/10/10 9:03
Re: head lights
My 73 1200 has headlight relays...
Posted on: 2005/10/10 11:41
Re: head lights
Not from Nissan Factory.
The car in question, might have had relays installed but a relay doesnt blow fuzes and operate in the described ways.
Posted on: 2005/10/10 12:39
Re: head lights
yeh so could i f ix it myself or buy one from a spare part shop
Posted on: 2005/10/13 5:38
Re: head lights
I'm just sayin mine has a headlight relay...u most likely have a short somewhere...
Posted on: 2005/10/13 12:46
Re: head lights
Can you test the circuit yourself to find the actual cause of the problems? If you can, you should be able to assess whether it is repairable or not.
It costs money just trial and error guessing if you purchase parts.
Posted on: 2005/10/13 12:51
