Re: my car very slow...
From Cyberjaya, Malaysia
check your carb also...
on free rev it should be able to straight rev to 5k freely
Posted on: 2005/10/3 10:19
From Melbourne, Australia
i was thinking about the cam, as the motor came from a van, it will have a cam which will favour low rev torque as oposed to high reving power... as with the timing and tuning
ive only driven a15s which had aftermarket cams so am unsure of how large the difference will be
also
there's always lightening the flywheel to get a bit more "free reving" from it, though this is an extra improvement rather than solution to your problem i feel
i think you could possibly use the a12 flywheel to shave some weight there (someone confirm please???)
Posted on: 2005/10/3 15:55
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
can i change my cams to A14 cams that have higher profile?
or any recomendation for a mild cam?
Posted on: 2005/10/10 8:28
The weight of the flywheel should not affect the maximum speed, but will affect how quickly the engine increases, or loses speed.
As the engine capacity increased through the various models of A series engines, so too did flywheel weight, so using a 1200 flywheel on an A15 will be a reduction in weight compared to the original.
Posted on: 2005/10/10 12:32
Love your Datsun.
Treat it well.
hi all..
is it the A12 flywheel direct fit to A15? any modification needed?
i do notice the engine response (rev up and rev down) not as fast as A12....
later i go try on rev it straight until 5k rpm on neutral gear..
btw, about the camm..
so i need different angle one?
will the A12 one fit my A15? any differnece will it made?
Posted on: 2005/10/13 10:50
From sydney australia
i'd try & get a cam from a b210.these will fit into your a15,& are much better than the cam
you already have.these are the cams i try & get when i'm having a cam reground.
the a12 flywheel will bolt onto the a15.i've done this before,& the engine does seem a little more responsive.
Posted on: 2005/10/13 11:53
oic..
so i can use back my a12 flywheel (maybe trim it a little bit)
and also use back the cam? (a12 from B310 is it same with B210? )
Posted on: 2005/10/14 16:10
« 1 (2)
