E.O.I complete ca18det 1200 conversion package
this is almoast a everything you could possibly need to complete a ca18det into datsun 1200
there are plenty of things i have forgot, any questions or parts please email
i am located in melbourne.
CA18DET
NEW DURA GLIDE ACL RING SET
NEW DURA GLIDE ACL MAIN BEARING SET
NEW DURA GLIDE ACL BIG END BEARING SET
NEW NITRATED CRANK WITH DRILLED AND SCREWED JOURNAL PLUGS
REBUILT AND TANKED HEAD ALSO CRACK TESTED
NEW HEADSTUDS AND WASHERS
TANKED AND HONED BLOCK
FULLY BALANCED BOTTOM END FROM CRANK, RODS, PISTONS, FLYWHEEL AND HARMONIC BALANCER
NEW DAIKIN EXCEDY "TUFF" CLUTCH KIT INCLUDES THRUST RACE
MACHINED FLYWHEEL
ULTRA SONIC CLEANED INJECTORS WITH ALL NEW SEALS AND BASKETS
TANKED INLET MANIFOLD AND T/B
REBIULT STARTER MOTOR
EVERY SEAL AND GASKET REPLACED WITH NEW
NEW CAMBELT
NEW IDLER AND TENSIONERS
OIL PUMP REPLACED AND PACKED
NEW WATERPUMP
MANUAL DET COMPUTER AND LOOM WITH IGN MODULE AND AFM
ADAPTOR PLATE AND TRUST AIRMAX POD FILTER
TURBOSMART ELECTRONIC BOOST CONTROLLER
BLITZ BLOW OFF VALVE
5 SPEED MANUAL DET GEARBOX
ENGINE IS FULLY ASSEMBLED
1200 BITS
MADDAT STYLE 1200 CA18DET ENGINE CROSSMEMBER
TOYOTA TA22 NEW HYD CLUTCH MASTER CYLINDER FOR 1200 CONVERSION
NISSAN SILVIA S13 TRANSMISSION TUNNEL TO WELD IN
NEW HYD CLUTCH SLAVE CYLINDER
CA18DET SILVIA RADIATOR
NEW INTERCOOLER 600X300 CORE SIZE
CUSTOM SHORTENED AND BALANCED TAILSHAFT
1200 UTE DIFF WITH NEW PEDDERS SHOCKERS
120Y LARGER SWAY BAR
STANZA FRONT END, CASTOR RODS, CONTROL ARMS, ALL WITH NEW POLYURETHANE BUSHES
STANZA STRUTS WITH NEW PEDDERS SHOCKS
240K 253MM NEW DISC ROTORS ON REPACKED HUBS
REBUILT 240K TWIN PISTON CALIPERS, WITH SEAL KIT AND NEW PISTONS
COMPLETE FRONT AND REAR SUSPENSION BUSH SET, POLYURETHANE, PRETTY MUCH EVERY BIT OF RUBBER UNDER THE CAR NEW
ALL NEW TIEROD ENDS INNER AND OUTER PLUS NEW BALLJOINTS
SET OF 4 ET TURBO ALLOY WHEELS AND 4 STOCK DATSUN RIMS WITH GOOD TYRES
THERE IS MANY MORE SMALL THINGS I HAVENT MENTIONED
EASILY OVER $7000 SPENT
THIS IS BASCIALLY EVERYTHING YOU NEED FOR THE ENTIRE CONVERSION.
EMAIL FOR PICS
also for sale spare det computer and loom
spare ign module
Posted on: 2006/1/28 2:15
Re: E.O.I complete ca18det 1200 conversion package
Quite a regular
From Perth, WA
do you have the gearbox crossmember? if so how much for the engine and gearbox crossmember?
Posted on: 2006/1/28 5:25
From California
uh, doesn't sound like a dealer does he?
Posted on: 2006/1/28 18:31
hey there mate! yeah i have gearbox x-member too! but sorry not wiling to seperate!
Posted on: 2006/1/29 2:01
From Melbourne, Australia
you got a price for the package? you still considering if you want to sell or not?
whats the story here?
Posted on: 2006/1/29 2:04
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
From Adelaide
i think u should seperate the engine and then sell it to me. if you are willing to seperate pm me
Posted on: 2006/1/29 5:31
From Sydney, Australia
It's a good package to be sure.
Bighatmat..I've shared too much time here with you..I was thinking the same thing..but I bit my tongue.
If anyone wants to do it properly, this is the opportunity to get all the parts you need.
To all wouldbe buyers....'This will save you months of screwing around, looking for parts!'
Cheers
Posted on: 2006/1/29 5:45
From campbelltown (sydney) australia
sounds like an awesome package, why are u selling it all when it sounds like it just needs to be put in? have u found a car with all this stuff already done?
Posted on: 2006/1/29 6:03
* caution, sunglasses must be worn to view my ca18det *
hey guys!
the story is,
had to sell my 1200 ute, which all this gear was going in, now i dont know if im gonna get another 1200 or not!
ive just opened my own business and dont have the time, i really want to keep it all but in the back of my mind i know that ill never do it so i thought id let you guys throw a few offers at me and maybe id bite.
i dont have a set price cause the package is priceless to me. it is just about everything you will need.
also i forgot to put in, there is a brand new EFI Hardware surgetank, bosch efi pump and peirburg feed pump to go with the package too.
some one care to explain what the dealer comment means???
Posted on: 2006/1/29 6:08
From Adelaide
where u from?
Posted on: 2006/1/29 11:13
