1200 coupe ride height.
From Adelaide
Howdy,
I'm wondering what the standard ride height for a 1200 coupe is?
The cops normally use the distance from the mudguard brow to the centre on the axle line as there measuring point.
Anyone know what it should be front and rear on a coupe
Cheers
Geoff
Posted on: 2014/12/4 11:00
Go Fast,
Or Go Home.
Re: 1200 coupe ride height.
From Goulburn NSW
I thought it was the lowest part off your car couldn't be any lower that 100mm.
Posted on: 2014/12/5 4:34
The factory ride height can be measured at the center of lights
710 mm to center of taillights
665 mm to center of headlights
170 mm to bottom of diff
Remember that tyre diameter will affect this, as well as modified/worn springs.
Posted on: 2014/12/5 5:56
From Adelaide
Thanks for the feed back.
i'm running 15" wheels so the wheel diameter will be different to standard. i'm in the process of fitting IRS and wanted to get the heights of the wheel hubs right, so if anyone knows the standard brow to axle center line it would be way helpful.
thanks
Geoff
Posted on: 2014/12/5 6:44
Go Fast,
Or Go Home.
