What Diff to Use in a 120ySSS
Not too shy to talk
From New Zealand
Any one have EASY Answer for me.
Have a 1975 120ySSS (NZ Model) with 5 Speed Box
Have all the HP I want now (195HP),
But Now need to change Diff Ratio.
I was told a 1200 Ute Diff Head would Bolt Sttraigh in ???
( Heard that one before)
But if ANY ONES Done it or can advise,
Much Apreicated
Posted on: 2006/3/23 11:43
Re: What Diff to Use in a 120ySSS
From sydney
I am thinking that a 120Y should have an H150 or a Borg Warner diff, neither of which will take the ute diff H165 head.
Posted on: 2006/3/23 11:57
From The Dat Cave.
He lied, it wont, but you should be able to fit the whole ute rear end without too much trouble.
Posted on: 2006/3/23 12:04
Have a 1975 120ySSS ... (195HP)
Using the original A-series engine? It must be either a high RPM race engine or supercharged. Would love to hear more details.
Posted on: 2006/3/23 17:52
most probably jap spec moddified L series 120 Y
Posted on: 2006/3/24 0:11
From sydney
Says its the NZ model SSS, which was an A series.
Posted on: 2006/3/24 0:16
What ratio do you want to change it to. There are a limited number of ratios available in the different diffs, & the bigger, stronger ones, which have the widest range of ratio's, will need to have their axle housings narrowed, & axles shortened to fit under.
Posted on: 2006/3/24 1:14
Love your Datsun.
Treat it well.
From Wellington New Zealand
The early pre 80' utes ran the 145 diffs and they were 4:1:1. Though a 145 won't handle 195 Hp. Look on Trademe at the moment and you'll find at least 3 165 roadstar ute diffs for sale. They almost bolt straight in and will handle the power you have if you are gentle.
Posted on: 2006/3/24 1:23
1200 coupe 1400 GX 5 speed
1200 coupe LHD peripheral port 12A rotary.
1200 ute
Sunny 310 SGX.
Not too shy to talk
From New Zealand
Hey thanks for the info, You say a 165 Roadstar would fit the STD 120y Diff,
Any idea what's actualy involved, is it a Real Major?
Also I'm in NZ and can't log ont on TradeMe Australia, You couldn't send a Link to get me on ?
Shame thre wer't more diff options for the 120y
Cheers.
Posted on: 2006/4/13 9:59
From sydney
I think you will find it wont fit the STD 120y Diff, not the other way around.
Stirling Mac is talking about TradeMe in New Zealand.
Cheers.
Posted on: 2006/4/13 14:38
