« 1 (2)
Re: change MPH to KPH ???
From Brisbane Aust.
If you take your MPH speedo out of the cluster you will notice that the KPH is actually marked on the section under the MPH figures ie on the metal plate that holds the speedo mechanism.
You can then check any artwork you make to cover the MPH figures with the KPH lines on the lower plate.
hope this makes sense!!!!!
Posted on: 2006/4/3 23:16
« 1 (2)
