« 1 2 (3) 4 5 6 ... 9 »
Re: H165 LSD's, making them now
Is there anyone missing from the list who has given me a deposit?
Posted on: 2006/3/22 11:38
bump...
Posted on: 2006/3/31 2:50
From Millgrove Vic OZ
Any idea on when the h165's will be available?
Posted on: 2006/3/31 11:11
Cheers Feral
I am hoping to have them in heat treatment next week, trying to get finished asap as I have to finish some H190's as well...
Posted on: 2006/4/1 6:07
From Perth
So just refresh my memory
I haven't ordered one but I have some questions incase I wanna
H165 is 1200 ute diff right ?
I thing I have a sunny housing in my car but we keep stretching the alloy 1000 coupe carriers
We will be putting more HP thru the car when the efi and new pistons go in next year
Then we are planning an SR NA upgrade
I only want to change the diff once
So
What diff housing should I look for in the sunny type width to be able to take this centre ?
What car would have a 3.9:1 ratio we like to use ?
Would the H165 stand up to the power of both A15 and SR20 ?
Cause I might want one if the H165 will satusfy the needs
On alother note
Topgear..... have you ever thought about making centres for Holden Banjo diffs ?
The torana boys went apeshit when I showed them your pics
They find it hard to get LSD centres for them too
Cheers
Neil
Posted on: 2006/4/1 11:14
Yes the H165 LSD's are to fit the 1200 UTE diff.
The Alloy centre is from the 1000 with a H145.
I am pretty sure the H165's have the availability of a 3.9 ratio, might be from Jap Stanza diffs?? Would be best to ask Ferral Errol about that, he's pretty up to date with what Datsun parts fit what??
I have never had any enquiries for the Holden diffs. I can do them no worries if they want. I do need to finish these diffs and the H190's first though. Let me know what you come up with...
Regards,
Topgear
Posted on: 2006/4/3 10:53
How much are the H190's and what crown wheel offset are you making them?
Posted on: 2006/4/7 0:43
Cheers Feral
Hi Ferral
The H190's are the same price as the H165's and I am making them to suit the Series3 Bluebird offset. How does that work in with what you are looking for?
Regards,
Topgear
Posted on: 2006/4/7 1:47
I could be interested in one of those as well. What is the offset between the bearing face and crown wheel flange; 80.4 or 84.4?
Posted on: 2006/4/18 14:00
Cheers Feral
The H190 offset is 84.4, is this what your after?
Posted on: 2006/4/19 4:07
