Browsing this Thread:
1 Anonymous Users
Parting out 73 Coupe |
From Vancouver WA. U.S.A.
Ok after driving my new 72 coupe, Kick in the pants to drive, I have decided to part out the 73 to fix the body on the new 72. There will be lots of parts available that I will not be using so if any one needs something let me know
Posted on: 2006/5/10 7:39
BE sure to check out my coupe build thread and feel free to leave comments good or bad.
[url=http://datsun1200.com/modules/newbb/viewtopic.php?topic_id=36107&fo
Re: Parting out 73 Coupe |
Registered Users Contentmaster Usermaster
I need one genuine air cleaner wingnut, the kind with the large diameter circle below it. By the way, are you going to the Trojan Nuclear plant caravan on Saturday? It is followed by a BBQ at the Datsun custom shop south of Portland. Hope to see you there. details: AMI BBQ
Posted on: 2006/5/10 17:25
Quite a regular
From San Diego, Ca
I need Dash parts if you have 'em...
will a coupe dash fit a sedan without too much modification?
What is your front suspension? if it's the disc I got first dibs.. ;)
Thanks.
Posted on: 2006/5/10 19:49
1972 Datsun 1200 - B210 Engine/Tranny swap, 240z 14" Rims w/ Falken Azenis 195/60-14 tires....
I think a coupe dash will fit a USA 2-dr sedan without any modification. They both look identical (round gauge dash). There is an article (two maybe) in the Tech Section that talks about changing dashes.
On the other hand, wiring varies a little between 1971, 1972 and 1973.
Posted on: 2006/5/11 5:19
I have a set of struts complete in good shape from a sedan w/ disc's and also a set from a coupe, also w/disc, dash I am not sure on if it will fit, do you need just a pad or a complete unit?. As far as drive train and suspension parts I have comple units from sedan, and a coupe.
Posted on: 2006/5/11 5:29
have you got clean (or staight at least) bumpers? front or rear? how about the front valance sheet metal? ..I also need the front turn signal housings and lenses in the valance...
located in santa rosa ca... but I am planning a trip to BC... I didn't even notice where you are located at.. well, I'll be in canada, and if you have some or all of these parts, and can email pictures, I'll paypal you payment now, and pick up later....? (wanting to make it simple for all parties)
let me know.. PM, or whatever..
-forrest.
Posted on: 2006/5/11 5:31
No genuine air cleaner wing nuts DD, I may be able to make it I may have to work. The only datto I have to drive has the smashed front clip
Posted on: 2006/5/11 5:32
Quote: have you got clean (or staight at least) bumpers? front or rear? how about the front valance sheet metal? ..I also need the front turn signal housings and lenses in the valance... Sorry no straight bumpers, they are pretty wavy, also the valance I will need, but turn signals I can help you out on
Posted on: 2006/5/11 5:34
damn bumpers are hard to come by.
what do you want for turn signals?... I guess they would be small enough to ship as well... you are in wasthington state?
maybe I'll look over my coupe tomorrow and see if I need anything else..
but the front turn signals, housings, wire pigtails, and lenses, for sure.
-forrest.
Posted on: 2006/5/11 5:38
From Huntington Beach, California
GM,
If you have a clean dashpad, I could use one. I could use a not-so-good one, too.
Duncan
