#1 Looking for A12 GX head gasket set
rventura Posted on: 2006/5/17 10:57
Hi, i'm looking for a head gasket set for my A12 Gx.
Anyone?
#2 Re: Looking for A12 GX head gasket set
ddgonzal Posted on: 2006/5/17 16:50
Use a standard 1971-1973 A12 gasket set along with an "A14" intake manifold gasket.
#3 Re: Looking for A12 GX head gasket set
rventura Posted on: 2006/5/17 16:54
Thank's!
I'l do that, but the head gasket is very thin... 0,8mm (original) to 1,2mm.
#4 Re: Looking for A12 GX head gasket set
ddgonzal Posted on: 2006/5/18 3:52
That's even better. Why do you want the thick one?Quote:
NISSAN COMPETITION (for all A-series engines)
11044-M0821 COMPETITION HEAD GASKET Gasket has a bore of 79mm/3.11", an uncrushed thickness of 0.8mm/0.032" and displaces 3.9cc's.
Have you talked to the Nissan dealer?
The stock A12 GX gaskets have a different part number. I'd guess it is thinner, as they have the same bore and block as the standard A12. Any of these should work on an A12:
A12
11044-H1000 GASKET-CYLINDER HEAD
11044-H1025 (newer, with separate oil o-ring)
11044-18004
11044-H3900
11044-H3901
11044-H3902
11044-H3925
List Price: $21.36 USD
A12 GX
11044-H2300
11044-H2325 (separate oil o-ring)
#5 Re: Looking for A12 GX head gasket set
rventura Posted on: 2006/5/18 17:42
- NISSAN COMPETITION (for all A-series engines)
Can you get this Head Gasket there?
I cant find it in Portugal...
If yes, can you tell me where, or can i send you $$$ for you to by it and send it to me?
#6 Re: Looking for A12 GX head gasket set
ddgonzal Posted on: 2006/5/19 3:20
The Competition gasket is the thin one. Did you say you wanted a thicker gasket?
The primary feature of the Competition gasket is it will fit overbored A15s. And smaller engines too.
#7 Re: Looking for A12 GX head gasket set
webbs1200 Posted on: 2006/5/19 3:32
#8 Re: Looking for A12 GX head gasket set
rventura Posted on: 2006/5/19 10:13
This is the 98.500 Klm A12 GX.
I wiil post a picture of the head gasket later...
#9 Re: Looking for A12 GX head gasket set
rventura Posted on: 2006/5/29 14:45
I sent 3 e mail's and didn't got response...
#10 Re: Looking for A12 GX head gasket set
ddgonzal Posted on: 2006/5/29 19:01
rventura, why do you want the thin 'gx' gasket, especially when yours has been using the thick one? The regular gaskets are thicker, and fit the gx engine. If the head has ever been 'shaved' (milled) then the thicker gasket is called for.
