Browsing this Thread:
1 Anonymous Users
help |
Not too shy to talk
From Burnie, Tasmania
ok i really need help here i took the front wheels off my 120y to check how much there was left on the disk brakes then put the wheels back on and tightened the nuts now when i drive the ride is really bumpy theres a durg durg durg durg noise coming from both wheels and when i use my brake theres that noise again very loud and very fast its the same with going around corners
im not sure what ive done wrong but if anyone has any ideas on whats wrong and can offer some info to help please do
Posted on: 2006/6/5 3:11
Re: help |
Registered Users Contentmaster Usermaster
There's only one thing to do: remove the wheel and look ... you will probably spot the problem ...
Posted on: 2006/6/5 6:11
Re: help |
From Brisbane
didn;t put the wheels nuts on backwards?
Posted on: 2006/6/7 15:16
Re: help |
From Ipswich, QLD
mate check your thread and make sure all nuts are done up evenly, its possible that you may have damaged the hole your bolt goes through and this is causing an imbalance, hence the chug chug chug noise. ty
Posted on: 2006/6/8 0:35
