« 1 (2)
Re: Gearbox Assistance Needed
From Bunbury Western Australia
you can pick up a T50 box for about $250 depending on model T2 (20 output plines) or 3T (22 output splines) the T3 box is a bit stronger and has a larger input shaft bearing which is inportant to know as dellow sell different conversion kits for both the boxes.
You will need to have the nose of the gearbox machined a bit to accept the the datsun throwout bearing as the toyota and datsun parts are different. you will also need a custom made tail shaft too.
The T50 box is a better choice I believe as it has closer ratios than the Datsun 5 speeds too
Posted on: 2006/6/23 3:29
Two things that drive me nuts.....a dry road under a grey sky and a wet road under a blue sky, because no matter what, it's either too soon or too late to drive the way I want
From Bendigo, Victoria, Australia.
Tyrie wrote:
....and you'll have to do some cutting in the trans tunnel.
i thought 1 of the benefits of the T50 'box was that it didnt need any cutting of the tunnel?
like blofly said, just a bit of maching of the thrust bearing race and thats it.
all the speedo and everything fits up easier than a 63A or 60A 5spd apparantley.....
Posted on: 2006/6/23 5:50
"Like a Rolling Stone"
Bob Dylan
New Daily: <<<<Now For Sale.
1972 B110, 13" Bathurst mags, airbrus
« 1 (2)
