Dry sump
From Christchurch, New Zealand
I found this site on the net, If you've got tons of cash they make some great dry sump kits for A series engines (and just about everything else).
http://www.drysump.com/index1.htm
Posted on: 2002/12/26 12:48
Re: Dry sump
Webmaster
From Lisbon - Portugal
Webmaster
Cool, submit the link.
thanks.
daniel
Posted on: 2002/12/26 12:55
Keep them alive and sideways!
Re: Dry sump
From Melbourne, Australia
advantage of dry sump???
btw daniel like what you did with preview/submit buttons
Posted on: 2002/12/26 13:03
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
Re: Dry sump
The main advantages of dry sump as I understand it are:
1) Reduced windage losses, meaning less friction caused by excess crankcase oil hitting the crank.
2) Remote oil tank, oil is held in a remote tank which can be as large as is desired therefore oil temp can be minimised.
3) During hard cornering you don't have the problem of the oil running away from the pump pick-up.
On the down side:
1) Its EXPENSIVE.
2) There is a bit of extra power used in running the external pump.
P.S. the reason it intrigued me is that using an external oil pump and management computer would mean no need for original cam in my proposed twin cam engine (refer twin cam thread)dry sump kits
Posted on: 2002/12/26 13:21
Re: Dry sump
fair enough
power? mechanical or electrical power, is the oil pump run off the motor still or can it be electric?
Posted on: 2002/12/26 13:32
1200 Coupe Rallycar
Re: Dry sump
Normally runs off a belt similar to a toothed cambelt.
power loss is probably made up thru windage reduction, although the amounts we're talking about really only apply to race cars (my interest is that I might be able to do away with the timing chain assembly)
Posted on: 2002/12/26 13:38
Re: Dry sump
Webmaster
Webmaster
Thanks! just some behind the scenes updates!
daniel
Posted on: 2002/12/26 15:38
Re: Dry sump
Windage is increasingly important at high RPMs. As RPMs increase, hp lost to windage increases exponentially. A dry sump is not needed at 6,000 rpm, but can save a lot of hp at high rpm. In other words, if the RPMs double, the hp lost to windage more than doubles (I think it squares, i.e. 4x).
At low rpms, windage trays work fine (even in stock pans), and special pans can include oil pump doors ad baffles to keep the oil near the pickup at high gs.
That alloy pan in the photo album sure looks cool.
Posted on: 2002/12/27 6:18
Re: Dry sump
From Perth
I contacted them and this is the reply
Neil, I'll give you the prices here- Dry Sump oil pan- $365, dry sump pump 3 stage- $ 695, drive pulleys and belt- $110,
remote filter adaptor-$78, Dry sump tank, 1.5 gallon $338 You will need to make a plate to mount the pump to your block and a mandrel to drive off the crankshaft. Thanks, Gary
This is all in U.S $ so for us Aussies double it and add freight. Duty too if you get caught, which is more likely now with them checking so much stuff that comes into Oz now.
I just want the pan. I can source the pump and everything else locally. I have a very good though not cheap engineer locally who makes dry sump pumps. I know he does good work.....after all he pilots a Nitrobike to 6 second passes which he builds most of himself (Jay Upton)
Posted on: 2002/12/31 3:43
Re: Dry sump
From Millgrove Vic OZ
You can fabricate a dry sump pan cheaply using a rolled steel section. Cut the sides and base from the stock sump and weld in the new scraper and sump pan to the block flange section of the original sump. The losses from oil hittting the crank are exponential vs rpm and are as high as 10 crank hp @ 8500 rpm. You are only removing an energy parasite by fitting a dry sump.
Posted on: 2003/3/22 12:16
