Weight of all 1200s
From Gold Coast
What weights in kilos are rolling 1200s.
Coupe
Ute
Sedan
Wagon
Posted on: 2006/7/18 1:12
z18-microtech-frontmount-t3/t4
-external gate-screamer pipe-
Re: Weight of all 1200s
From SE Melbourne
From the factory
2dr sedan 720kg
4dr sedan 715 kg
2dr coupe 730kg
Ute...not sure
Theres a start...
Posted on: 2006/7/18 2:47
Mildman, Datsunless
Not too shy to talk
From Melbourne.au
ute is 695kg
why is the 2 door sedan heavier then they 4 door variant?? and why is the coupe heavier then both of them??
do you have the values the wrong way around or is there a reason for this??
Posted on: 2006/7/18 2:58
From sutho shire, NSW, AUS
well for intrests sake my car got weighed last week. its a four door sedan with a CA18det, silvia gearbox, R31 diff and R31 fuel tank. it had about 50 L of fuel in the tak when i weighed it, it came in at a heifty 910kg.....i was surprised how much heavier than standard it was...oh well.
Elliott
Posted on: 2006/7/18 4:06
From Adelaide, South Australia
We've had this before and from memory everyone comes up with a different ute weight.
Posted on: 2006/7/18 4:08
"Anyone who has never made a mistake has never tried anything new"
Albert Einstein
Put stupid oversized photo here>>
From SE Melbourne
I have a little more info on these 3 models that might help piece the weight together.
It could be glass - I seem to remember hearing that the S13 silvia was lighter than the 180sx be a fair margin - one reason was the enourmous back screen of the coupe....
Dato 1200 2dr Sed 4dr Sed 2dr Coupe
Length 3.83 m 3.83 m 3.82 m
Width 1.50 m 1.50 m 1.51 m
Height 1.39 m 1.39 m 1.35 m
Wheel base 2.30 m 2.30 m 2.30 m
Weight 720 kg 715 kg 730 kg
Front suspension MacPherson MacPherson MacPherson
Rear suspension Leaf + shock Leaf + shock Leaf + shock
Front brakes Drum Drum Disc
Rear brakes Drum Drum Drum
Posted on: 2006/7/18 8:41
Mildman, Datsunless
It is in the structure
for some reason 2 doors and coupes weigh in a little heavier as they need more support for the bigger doors, Convertables I think weigh in heafty as well
Posted on: 2006/7/18 11:55
Don't You Just Love Owning a Road Registered GOKART
What?
Fact: the 2-doors weigh less than the 4-door.
Why do the weight figures quoted differ? Two main reasons:
1. Different sources weigh cars differently. Some are shipping weight, some "curb" weight, others with full tank of fuel, others will half tank, etc.
2. 1200 models from different countries have different weights. Likewise for different trims (for example, Standard models vs. Deluxe models)
Check out this, from one source:
4-dr manual 1532 lbs
4-dr auto 1609 lbs
2-dr coupe 1520 lbs
5-dr wagon 1609 lbs
Posted on: 2006/7/20 6:17
