#1 What can cause the ignition timing to fluctuate?
matty Posted on: 2006/7/23 8:50
The ignition timing on my CA18DET is all over the place at the moment. I have tried 2 different computers and 2 different crank angle sensors(condition unknown on both cas) with no improvement.
What can cause the timing to vary wildly?
Thanks Matty
#2 Re: What can cause the ignition timing to fluctuate?
blofly Posted on: 2006/7/23 13:42
a faulty knock sensor, crook wiring between crank angle sensor and ECU or between Knock sensor and ECU are the next things I would look into
#3 Re: What can cause the ignition timing to fluctuate?
matty Posted on: 2006/7/23 20:53
Thanks for the reply Blofly.
I have a couple of spare knock sensors so I'll swap one of them in this week and see if it helps.
Good tips about the wiring too.
Thanks again Matty
#4 Re: What can cause the ignition timing to fluctuate?
pager Posted on: 2006/7/23 23:36
Check your points! the CA18 are always having probs with the points
yer that was a poor joke but any way........
