how to connect auto-choke for hitachi carb?
hi all,
i have read this from the tech session
but not so understand
i not sure if i ask before.
there is one wire comes out forom auto choke
where to connect it to?
my car comes with stock A12 alternator,
i not sure if it have build in regulator or not, how to check that out?
cause when i transplant to A15, only engine and carb is changed, the rest is the same, but the mech never bother to connect the choke for me
all this while i leave the auto-choke not-activated.
Posted on: 2006/7/25 1:51
Re: how to connect auto-choke for hitachi carb?
Connect it to the '+' side of the ballast resistor (or coil if you have no ballast resistor).
Posted on: 2006/7/25 4:37
oic..
yea.. i located the coil
later i go check where is the "+" of the coil..
it is currently connected right? i have to duplicate the wire right?
Posted on: 2006/7/25 4:59
There are two posts on the coil, they are marked '-' and 'minus' on the plastic part of the coil. There will be one or two wires already on the '+' side.
Get a length of wire about the same diameter as the choke wire, and connect it up.
Posted on: 2006/7/25 7:10
thanks a lot
i will try that out.
really appreciate it
Posted on: 2006/7/25 7:57
hi,
i got find that terminal already
now just need to find one Y lung and crimp it to a wire and fix it..
really thanks a lot
Posted on: 2006/7/26 1:04
