strut/tower bar for 120y (B310)?
hi all
the strut bar that connect the 2 top mount of strut at your engine bay,
which can strengthen your chasis at that part.
anyone know our datsun B310 is same with which car?
cause i cannot find the one that is made for B310 here, so thinking of using one which is made for other cars , but have the same length.
anyone have suggestion?
thanks in advance.
Posted on: 2006/7/31 1:21
Re: strut/tower bar for 120y (B310)?
From Rocky Queensland
hey mate. im not 100% on this. but i didnt think they ever came out with a strut brace. most of the strut braces on dattos come from people who fabricate them themselves
Posted on: 2006/7/31 7:19
oic.....
cause i cant find it at my place
so i thinking.. might be other car's strut bar same size with B310..
but no luck so far
Posted on: 2006/8/1 1:23
im having help make some for the 1200 (b110). need a more accurat measurement or drawing of the strut top... for the plates but we are using an already made 2nd hand nissan one for the job... has adjustment too :)
if anyone can help with strut top dimensions, it would be great.
Posted on: 2006/8/1 11:15
From Adelaide, Australia
I dont know any measurements but B110 bolt spacing is the same as 120y. Stanza (A10), Sunny and most other datsuns are the same spacing but bolt sizes change.
Posted on: 2006/8/1 12:14
cheap + fast = disaster
fast + reliable = expensive
cheap + reliable = stock
IPRA Build
From Albany, NY USA
Bumping this old thread to see if anyone knows of a bar that will fit our B310's?
Or maybe one that can be modified to fit?
What are you guys using?
Mike
Posted on: 2012/1/12 4:06
Yes, they made them in Japan specifically for B310.
The bolt pattern is the same as A10/Stanza/510. But then the length of the bar is incorrect.
Posted on: 2012/1/12 4:44
120Y = B310 in many countries.
B110 and B210 both have the same bolt pattern (including B210 120Y). B310 120Y is slightly different as it uses larger diameter bolts.
Posted on: 2012/1/12 4:48
From Albany, NY USA
Thank you David. I contacted Cusco USA in Huntington Beach, CA. and found that they still make one for the B310. I have inquired about ordering one through one of their dealers, DentSport Garage in MA. They said they will let me know what it will cost on Monday.
Mike
Posted on: 2012/1/15 14:56
