« 1 ... 7 8 9 (10) 11 12 13 ... 91 »
Re: Datsun 1200 ute restoration and sale
From melbourne
so here you can see the old trim peeling off nice and easy so far huh!!!
Posted on: 2006/8/2 10:41
From melbourne
ok now we lay the old trim on the nice fresh masonite wood,the stuff im using has a white covering on one side,i find this helps with marking lines and holes etc but it really doesnt mater,
so we lay the old trim on this new wood and mark around the trim and mark the holes also......
Posted on: 2006/8/2 10:45
From melbourne
and here we have the marked board ,how we doing so far easy????
Posted on: 2006/8/2 10:46
From melbourne
so you have your marked up wood next you cut it out with a jig saw........
Posted on: 2006/8/2 10:49
From melbourne
then sand the edges smooth and drill the holes ,.....
and you end up with something like this...
Posted on: 2006/8/2 10:51
From Brisbane
this has to be a better deal than the fibreglass ones that dont match to the original shaped door trims ( total s... ) keep up the good work ..
Posted on: 2006/8/2 10:57
From melbourne
next we roll out the soft spongy foam which im using as a backing,you dont have to use this but i find the end up look is alot better and more comfy feel to the car,,
as you can see the cat likes the foam too!!!!
Posted on: 2006/8/2 10:59
From melbourne
well ive never had the fibre glass trims so i wouldnt know but this way is very cheap and pretty much spot on as you are taking a direct tracing of the original trim so hopefully your holes should line up reasonably well !!!! well they should if you do it right,
so next part is to cut out the foam making it a bit bigger than the trim..........
Posted on: 2006/8/2 11:05
From melbourne
ok having done all that we now get out the good old spray glue and spray the hole trim,get a fair bit on there but try not to get it around the clip holes or you may find it hard to replace the clips later on!!!,
wait a minute or so for the glue to tack off then place the foam on the glue and press down and let it sit for a few minutes to set ,
once set you can trim off the excess with scissicors..........
well thats about it for tonight more tomorrow nite hopefully ,
hopefully some one will get some use out of this ,its very easy and can make your interrior look real good !!!!!
Posted on: 2006/8/2 11:12
Quite a regular
From Tasmania
Very helpful. I was about to do this myself after I finish putting in the central locking.
Having problems finding the right fabric though :(
Posted on: 2006/8/2 14:07
