Nissan 240 engine in Datsun???
From Barranquitas, Puerto Rico
Hello eveybody. I am new to the club and have alot of things to ask you guys that I heard you could do to Datsun's.
I live in Puerto Rico were Datsuns are common sites. I have an uncle that all he does is work on Datsuns.
One day while I was talking to him about modifying my motor(A15) he said that it would be a good idea but it would be better to swap my A15 in favor of an SR20 motor out of a old 240. Not only am I confused on what I have to do to get it to fit in my 210, but I check out a couple of Nissan 240's and found out that motor comes turbocharged to. Please tell me what you think.
All replies will help me very much. Thanks guys!
Posted on: 2006/8/2 4:21
Re: Nissan 240 engine in Datsun???
lots of people have done it.a member homer has just finished putting the sr20 into his datsun and is very happy with it.
if you want power that is the way to go or you could use a ca18det which comes out of a 180sx lots of people have done it and are extremly happy with the power.
if u want to see some pics of the conversions go to YAJOKN's pictures have a browse through there he has put a ca18 into his ute or for the sr20 conversion go to EVEY's pictures.
you can also get info on how to do it in the tech section and tells you about all the otors that got into datsuns good luck
Posted on: 2006/8/2 4:57
Thanks, datto_lowrider93.
Just want to also ask would it be a good idea to get the turbo version of this motor or am I better of with the natural aspired motor?
Posted on: 2006/8/3 4:21
if ur satisfied with the power of the turbo version you should get it if not then you should buy the non turbo version and use the money you saved from the non turbo version to buy a bigger and better turbo hope ive helped cheers
Posted on: 2006/8/3 5:33
You be better off with non-turbo:
- easier to fit into a 1200 engine bay
- less expensive
- last longer
- you won't kill yourself from too much power ... ok you might still with 2 liters
Anyways, here is some limited info but more importantly pictures: Engine Swaps.
Posted on: 2006/8/3 5:37
Thanks a lot datto_lowrider93. Your very helpful. Thanks bud.
Posted on: 2006/8/3 16:42
Thanks ddgonzal. And about the killing my self with the turbo could be true do to the fact that my Datsun 210 will be a drag demon and a monster for drifting.Thank alot though.
Posted on: 2006/8/3 16:45
anytime datsundrifter1 glad to see i helped
Posted on: 2006/8/4 23:48
Quite a regular
not too sure if you can fit a KA24DE in your 210. I have one in my 510.
Posted on: 2006/9/7 15:40
OldSchoolImports.net... checkuh check it out!
Klassicks
Keep it real. Keep it all Datsun.
Posted on: 2006/9/7 17:35
