Late block A10???
From Perth WA
I know some of you blokes will be able to sort this out. has me stumped from what i have read.
With my 1000 Wags i bought came 3 A10s. 1 is differnt. It has a late A12 style block. Dizzy in the middle, fuel pump at the front, Rear crank breather, emmisions head(big thermo housing, round port). It has a A12 fuel pump on it and a 1000 metal fan
The engine number is A10 313598
anybody have any idea?
Heres a crappy pic, can get a better one
Posted on: 2006/8/16 12:29
Chris...
Re: Late block A10???
From Adelaide, Australia
I think they ran A10's in the E10 or F10 front wheel drive cars.
Posted on: 2006/8/16 12:48
cheap + fast = disaster
fast + reliable = expensive
cheap + reliable = stock
IPRA Build
From Perth
That clutch looks bigger then 160mm too
Keep rubbing....... might be an A12 restamped for rego
Posted on: 2006/8/16 14:48
From Adelaide, South Australia
Just looks like a late A-10-12 block does it have the emissions tap on the right side of the enigne between the front of the engine and the first exhaust port ?
Posted on: 2006/8/16 17:08
"Anyone who has never made a mistake has never tried anything new"
Albert Einstein
Put stupid oversized photo here>>
The distributor in that position indicates a 1974-or-newer engine.
Which Datsuns came with an A10 after 1973? There you will find the answer.
Posted on: 2006/8/16 17:33
Look at the front of the engines & compare the distance between the top of the timing case & the top of the block, [head gasket face] & compare with the 'regular' A10's
If this one has a bigger gap, then it has a longer stroke & would therefore be a re-stamped fraud.
Posted on: 2006/8/16 21:34
Love your Datsun.
Treat it well.
From Canberra. ACT
Yeah good idea dodgeman but hey are saying people would do something as terrible as that tut! tut! tut!
Posted on: 2006/8/17 5:09
What about the A10 engine in the 1976 Datsun 100A (E10 Cherry)? Would that have the new-style block?
Wikipedia
Posted on: 2006/8/17 5:24
From Freo
Looks like a 1000 flywheel though.. the rear face is as tall ts the ringear... ???
Posted on: 2006/8/17 7:08
From Perth WA
Well i think i solved the mystery!
It has a bigger gap from top of timing case to the deck of the block then the other A10s.
Plus where would i get a motor out of a Cherry in WA? I know of 2!
Posted on: 2006/8/18 12:38
Chris...
