« 1 (2)
Re: firing order for j15 in australia
Quite a regular
From Brunswick, Melbourne Australia
What's common between 1342 and 1234 is the 3&4 so maybe 1&2 are wrong, but you say 1 is TDC on the compression stroke. Are you sure? Love to see a photo, even better, a movie. You would need to have a different crank & cam shaft to all others.
Posted on: 2006/8/23 12:45
Not too shy to talk
From wyong
Thanks will try 1 & 2 , see how it goes ... il take a photo but the movie is out of the question!
Posted on: 2006/8/24 2:18
In australia the firing order is anti-clockwise. So starting with #1 plug wire count off 1243. Or clockwise, 1243.
lacks torque in 3rd / 4th gear no miss firing or backfire just slow on pick up??
That's how all Datsun trucks with J13 engine go.
Posted on: 2006/8/24 3:00
Not too shy to talk
From wyong
Ok sorry dude the firing order is 1243 not 1234 but it still strange i tried the 1,2 swapover & got missing and backfire so back to firing order? i got no idea but heres a picture of it anyway Dooffy Open in new window
Posted on: 2006/8/24 3:27
Not too shy to talk
From wyong
thanks for the reply i am a dooffy couse i posted my problem wrong the firing order is 1243 not 1234 how dumb. but it still says in my nissan factory manual the firing order is 1342 go figure
& the firing order you have given is what im running so it must b right is there any thing i can do to give her more pickup where needed thanks dooffy
Posted on: 2006/8/24 3:43
1342 is 1243 backwards!!!!
The dizzy runs the other opposite way to the crank! You have it set up right, you are just reading it backwards!
Posted on: 2006/8/24 7:25
dooffy wrote:
yep it does. it purrs during idle but lacks torque in 3rd / 4th gear no miss firing or backfire just slow on pick up??
It's a truck, ... with a low performance engine that is designed to haul a load, not haul arse, so this sounds about right.
Do you have all the tune up specs? It might not be a rocket ship, but there's no reason for it to be be any slower than it needs necessary. If you give it the once over in the tappet department, then set the dwell & the timing. Make sure that both the mechanical & vacuum advance are working as they should & it will run as good as it ever will without additional mechanical work.
Posted on: 2006/8/24 8:54
Love your Datsun.
Treat it well.
Not too shy to talk
From wyong
hey thanks gunna try the vacume,s today ill post u all to let you know i went thanks dooffy
Posted on: 2006/8/25 4:22
« 1 (2)
