anyone got info on this carb?
From The garage, NZ
Hey all.
Looking for info on a carb that i got with an a15. just wanting to know, will it work with A15 without mods, etc etc.
Selling my A15 and this is the only carb i have with it. Im thinking its off a late model sunny? has heaps of wiring on it which un-eases me as a series are ment to be bsaic as basic
Cheers guys
Posted on: 2006/9/24 10:17
Re: anyone got info on this carb?
From Perth WA
Looks like a A series carby. By the looks of it it has Electronic choke and lots of wanky emissions diaphrams... should work on a A15...
Posted on: 2006/9/24 11:43
Chris...
From Bunbury Western Australia
looks like it also has an electric anti dieseling solenoid and a thing that brings the revs up a tad when the air conditioning is switched on.
I have the exact carb sitting in the shed
Posted on: 2006/9/24 12:36
Two things that drive me nuts.....a dry road under a grey sky and a wet road under a blue sky, because no matter what, it's either too soon or too late to drive the way I want
I've never seen one with a solenoid on the throttle body plate (bottom of carb) like that.
Can you read the carburetor model number?
Posted on: 2006/9/24 18:01
From The garage, NZ
where abouts is the model number written ??
Could all that crap just be removed and used on an a15 like a old style carb?
Posted on: 2006/9/24 21:30
From Wellington New Zealand
It looks like a late model emmissions carb off of a late black top A15 from a Vanette. I would like to be more sure but I always rip the buggers straight off and throw them away...
Posted on: 2006/9/24 23:39
1200 coupe 1400 GX 5 speed
1200 coupe LHD peripheral port 12A rotary.
1200 ute
Sunny 310 SGX.
model number is on left side of carb body:
Hitachi ID Boss
Most of the time you can't remove all the emissions stuff. But don't worry it doesn't cause a problem. Just plug the hoses, none of them need to be connected.
However, in a street car you'll get better performance if you connect the vacuum advance port to the distributor.
Posted on: 2006/9/25 3:03
From The garage, NZ
carb actually doesnt have a number
Where its ment to be, it has a vacum daiphram over it and under that it only has what looks like a 3 inside a crazy circle.
Wierd.
Im selling this carb. What do you rekon i should say about it ??
cheers
Posted on: 2006/9/25 7:20
If it came from an A15, I would put it on and drive it.
Posted on: 2006/9/25 17:37
