datsun_guy wrote:
dont you have to tune the su's to the weather tho?
And SU's are different from other carbs in this regard because, .............?
A carburettor is just a mechanical device to mix fuel with air in the correct proportions. Some carbs are more complex than others & do a better job, but the one thing that most carbs can't compensate for is atmospheric pressure & humidity. [The weather]
Really cold days at low altitude will have higher atmospheric pressure, & when you are hot & high, the perssure will be less.
A variable venturi carb, like SU's & the similar looking Hitachi's, control the size of the venturi according to the relative vacuum in the manifold & this in turn controls the gas velocity across the jet. In effect, it more or less stabilises the gas velocity, allowing a more stable mixture control when compared to fixed jet type carbs. [at least, that's the theory]
My Hitachi's had a jet adjustment under the carbs which was both easy to reach & easy to adjust without any tools, so if your exhaust gas analyser says that you're running a bit rich when you are at high altitude during a heat wave, then leaning it out on the side of the road will be a lot easier than with any fixed jet type of carb.
Conversely, next time you are in Death Valley [below sea level] during a snow storm, you can richen up your SU's or Hitachi's a little without any real drama.
Generally speaking, once your carbs [any carbs] are correctly set for the area where you do most of your driving, you will be fine.
