Anyone using stock diff wit a CADET
From Radelaide, South Australia
hey all, anyone using the standard diff when
you do the ca det swap..
if yes, how many have you minced...
Posted on: 2006/10/15 9:47
Boost.. boost.. BOOST!!! Gotta love Lag...
* 76 coupe, twin 40mm a12, project...
* 79 ute ca18det, track/street...
* 84 FJ45 landcruiser project...
* 88 D21 navara 4x4, sr20de vvt daily...
Re: Anyone using stock diff wit a CADET
I have a welded ute diff in my sedan.
i'm running a brass button clutch, and i give it hell, and it hold up great. the axels are the thing that brake.
Posted on: 2006/10/15 10:37
cheers mate.. thanks for the info.. mine is welded up in my ute, and the engine is close to being bolted in..
Was not sure if i should worry about the diff till a later date...
cheers again.. Dane.
Posted on: 2006/10/15 10:47
just leave it for now and if it shi7s it self do it then.
Posted on: 2006/10/15 11:48
Quite a regular
From Adelaide
i use the later model borg warner diff in the 120y and FUK am i sick of replacing axles ha ha
Posted on: 2006/10/15 12:56
